It is currently Thu Jun 26, 2025 12:17 pm
PostPosted: Thu Feb 23, 2023 11:54 am
Is it an easy option to ad a timing chain tensioner to my Mk2 Cooper S?
What are the requirements and/or modifications?
PostPosted: Thu Feb 23, 2023 12:26 pm
Not commonly done.
I did it once on an S motor that had a loose chain, because the block had been line bored. That had shortened the sprocket centres. That also retarded the valve timing.
You need:
A+ timing chain cover and gasket.
A+ engine front plate.
A+ single row tensioner assembly. Duplex one is NLA for many years.
Single row one works.
Offset cam key. I needed a 9deg one. You may not but check valve timing on assembly.
I built this motor 20+ years ago for a friend and it is still running fine.
PostPosted: Thu Feb 23, 2023 12:57 pm
Guess I need an offset cam key to take the slack out of the chain.
PostPosted: Thu Feb 23, 2023 1:27 pm
That won't take the slack out. What chain is it, many are Asian rubbish now.
Iwis German made endless is the best. Not cheap but worth it.
You shouldn't need a tensioner unless block has been line bored since manufactured.
PostPosted: Thu Feb 23, 2023 1:52 pm
The offset woodruff key is to adjust the cam timing vs the crank. It won’t affect the tension, as the Dr says
PostPosted: Fri Feb 24, 2023 9:00 am
If the engine has been line bored then wouldn't the main bearings be larger than standard bearings?
PostPosted: Fri Feb 24, 2023 10:53 am
When you line bore the block, you remove material from the main caps, then rebore while taking as little material off the block as possible. You essentially just move the bearing surface towards the top of the block while maintaining the bearing bore diameter
PostPosted: Fri Feb 24, 2023 11:01 am
So if your engine has been line bored the timing chain is going to have some slack?
PostPosted: Fri Feb 24, 2023 11:08 am
Yes. With standard sprockets and chain.
PostPosted: Fri Feb 24, 2023 1:15 pm
And keeping in mind that generally you only need to line bore the block if a main cap is missing or damaged or the bearing tunnel is damaged from a spun bearing.
PostPosted: Fri Feb 24, 2023 4:16 pm
Is there any difference between a Cooper S chain cover and a Mini chain cover? I ask because the chain is duplex.
PostPosted: Fri Feb 24, 2023 4:25 pm
Some Mini timing covers have a metal reinforcing across the centre. Cut it away if fitting a duplex chain.
Also note the oil slinger for duplex chain is narrower than other Mini ones.
PostPosted: Sat Feb 25, 2023 7:51 am
Rollmaster make duplex timing gear sets for line bored blocks that negate the need for A+ tensioner set-up. Have +0.002" and +0.005" new sets available.
Steve
PostPosted: Sat Feb 25, 2023 8:00 am
What is the Mk2 oil slinger part number?
PostPosted: Sat Feb 25, 2023 3:36 pm
I believe this is it but others can confirm - 12A1148. Available from most Mini parts suppliers.
