It is currently Thu Jun 26, 2025 3:26 pm
 Post subject: Cindy the Moke
PostPosted: Sat Feb 18, 2023 3:27 pm
Cindy the Moke as a 1100S 1310 maybe 1303 something build by GR with a GR266ss I believe its a ss Cam.
It has a 1 1/2 SU with a #06 needle in it and the Dizzy is a modified Pulsar dizzy I have been using in the 1412 for some time now.
She had a good run from the central coast and back again without any problems but I believe the cam should not have a ruff idle which she didn't really want to sit on 60klm also
Last week I took her for a quick trip and she just was not running correctly like a lead or plug had let go.
#2&3 were ritch but not wet while 1&4 were perfect. I have since checked plugs and leads and all are good. I have just checked the rocker clearance and they are @ 15"
Start here up and she has the ruff idle again but I can't get the idle down under 1700 on the tacho even with adjusting the dizzy back to DTC. Yes the leads are 134 and no air filter
 Post subject: Re: Cindy the Moke
PostPosted: Sun Feb 19, 2023 6:17 am
Hey Gaf long time no hear from!
Bring her around and I'll put the A/F meter on.
I still have a bunch of SU needles here. :mrgreen:
PostPosted: Sun Feb 19, 2023 8:42 am
G'Day Dr
Yes it has been some time and much has happen since. Not that easy to bring Cindy around as we are between Gosford and Newcastle now. I will be down dropping Owen off this afternoon so I can pop in for a chat but with out Cindy
PostPosted: Sun Feb 19, 2023 9:46 am
See you then.
Users browsing this forum: Bing [Bot] and 91 guests
