It is currently Wed Jun 25, 2025 7:58 pm
 Post subject: Heater plastic body type
PostPosted: Sat Feb 11, 2023 9:59 am
Does anybody have dimension details of the fitting that connects the heater outlets to the screen heater hoses on the plastic bodied heater box? A picture of this would be of some help
I assume it is some sort of plastic fitting.
Many thanks
Mk1 Cooper S
Mini K Rally car
PostPosted: Sat Feb 11, 2023 12:07 pm
Is this what you mean
The smaller end is 55mm od
The larger end is 61mm od
Measiring around the outer curve is 140mm
Inner middle to larger outer is 45mm
Inner middlie to smaller end is 40mm
Cheers Dave.
PostPosted: Sat Feb 11, 2023 2:20 pm
Thank you so much. I had assumed it was a straight fitting.Just complicates the making of the part.
Mk1 Cooper S
Mini K Rally car
PostPosted: Sat Feb 11, 2023 6:17 pm
I’m sure there’s a lot gathering dust in sheds, a wanted post might find you a pair
PostPosted: Mon Feb 13, 2023 11:10 am
Thanks Timmy I will have a go but will try Brian at Link first
Mk1 Cooper S
Mini K Rally car
PostPosted: Fri Feb 17, 2023 9:32 pm
if you get stuck i can 3d print you one no problem
Users browsing this forum: 1071 S and 97 guests
