It is currently Mon Jun 23, 2025 1:50 am
 Post subject: RTS clutch
PostPosted: Mon Jan 23, 2023 9:20 am
Gday
I am currently in the process of building a turbo charged A series. I have read and watched a number of rts builds just wondering if anyone here in Aus can build one for me?
cheers Jason
 Post subject: Re: RTS clutch
PostPosted: Sat Jan 28, 2023 2:46 pm
never heard of it - links?
google only finds "RTS Clutch" as a brand name
if you haven't already, look at turbominis.co.uk, there will be plenty of recommendations
PostPosted: Sat Jan 28, 2023 5:50 pm
It’s a verto clutch with two diaphragms. I’d think Matt Read at Readspeed would be your best bet at someone local who can knock one up for you
There’s a few threads on turbo minis.
http://www.turbominis.co.uk/forums/inde ... tid=437563
PostPosted: Sun Jan 29, 2023 8:26 am
Very interesting, thanks Timmy - looks easy enough to put together
PostPosted: Sun Jan 29, 2023 10:13 am
Jason -
also on that site are plenty of disclaimers regarding 'do so at your own risk' -
not that there is anything wrong with the set up - just that the 'inventor' wants it to be stated very clearly - so there is no recourse if something bad happens.
In my opinion- it tends to be a clutch you build for yourself rather than build for others.
Simon what clutch set up did you run when you had your Supercharger? and approx what power did it produce - I am wondering how much above 140-150 (at engine not wheels) a well set up grey or double grey (if still available) diaphragm will handle.
PostPosted: Mon Jan 30, 2023 11:17 am
Gday thanks for the replies
Matt Read doesn't do them but has heard of them, he has some of his own modifications for the Twinky builds but these not readily available
Your right there is quite a few threads on uk forums, there are also a few guys in the uk building them for sale (simon mk1 turbo, SC components and HRE) and hence my question whether anyone had one built in Australia, i do know of one in a car. for those of you who follow classic mini DIY this is the same used in the turbo build. Reading threads on the turbo site they have clutch slippage with grey setup but they are 140 + at the wheels.
I have a list of components so i might keep the tread alive once the parts arrive to keep everyone informed
thanks everyone Jason
PostPosted: Sun Feb 12, 2023 10:43 am
It had 100bhp at the wheels at about 5800 rpm - no idea about engine power - pretty sure I had a grey diaphragm and just a standard Cooper S type plate. It never slipped
I was actually testing the dyno rather than tuning my car, my guru had been offered it by the local tech high school who were replacing it - we set it up and I was making it work... it hadn't been used in a lot of years. The rollers were too far apart for the mini wheels so the back roller was scraping on the exhaust. I did a few tests with my mini, one being running it up till I couldn't stand the noise from the scraping anymore. The dyno showed torques and speed, I calculated back what the bhp and rpm was and got a bit of a surprise that the bhp was higher than I expected, and the rpm quite a lot lower
A clutch and flywheel is just a bolt-on - I'd set it up with something simple (grey or whatever) and see if you need to go bigger later. There are much bigger problems to solve before you get to clutch slip
PostPosted: Mon Feb 13, 2023 8:38 am
:lol:
PostPosted: Tue Feb 14, 2023 1:25 pm
Thanks Simon, My rationale is that id rather try to get it right the first time as i will balancing the crank and flywheel together... well that's the plan.
