It is currently Fri Jun 27, 2025 7:16 am
Post new topic Reply to topic  [ 59 posts ]  Go to page Previous  1, 2, 3, 4
 Post subject: Re: How To Fit Badges
PostPosted: Fri Feb 10, 2023 11:30 am
Well .looks like the problem is solved for cooper s .I hope the badges fit well. His car must be nearly complete if he is fitting the badges good luck cooper s
Allen
PostPosted: Fri Feb 10, 2023 2:29 pm
Had trouble fitting boot badge it's snapped.
Guess I'll have to start over.
Pull the gearbox etc etc.
PostPosted: Fri Feb 10, 2023 3:31 pm
I have this template if that helps anyone.
 Post subject: How To Fit Badges
PostPosted: Fri Feb 10, 2023 7:46 pm
I have a similar template, bought a bezel and traced around the perimeter on to a piece of cardboard and used the pins to punch holes in to the cardboard, scanned it to a pdf and imported in to CAD, scaled and inserted a ellipse around the perimeter… printed 1:1, I know there’s lots of room for error, but it’s surprisingly accurate .. also happy to share the PDF if anyone needs it
PostPosted: Fri Feb 10, 2023 8:17 pm
_
PostPosted: Sat Feb 11, 2023 8:23 am
Sorry to hear the badge broke, the badge is die cast which is Cold short. heat the badge in hot water before fitting this will allow the badge to bend slightly without breaking. I used to do this all the time with Rolls R badges. Hot short eg Brass breaks or cracks when heated. I am surprised no one mentioned this fact. The badge must be put on evenly using your hand or a small hammer and a small block of wood.
Allen
PostPosted: Sat Feb 11, 2023 9:54 am
_
PostPosted: Sat Feb 11, 2023 3:38 pm
Eight fifty thanks for the information, as you are aware there is zinc and aluminum die cast .Very few people would repair this material .I have repaired many die cast car grilles and head light surrounds and if they are bent we always heated the material this made it return to the correct shape without cracking or breaking the material .Ask an old blacksmith if there are any left he would confirm this. Text books do not tell you how to repair die cast this has been done over many years using trial and error. Obviously you have used this heating method and it did not work for you ,text book repairers do not go far in the REPAIR industry. Anyhow thanks for your input. If Larry had warmed the metal it may not have broken.
Allen
PostPosted: Sat Feb 11, 2023 8:18 pm
You got it Brad. I've asked Doug to delete my account. I've got better things to do than listen to ignorant comment.
PostPosted: Sat Feb 11, 2023 9:18 pm
I am very sorry to see Ausmini lose this input from someone who worked at BMC/Leyland and who could offer technical information that help us all in many ways.
It is sad when sarcasm and cheap, petty personal remarks replace a respectful discussion of different opinions.
And spare a thought for moderators and others connected with Ausmini administration who must wonder why they continue to devote time and effort to an unpaid job that can be spoilt by these petty outbursts.
PostPosted: Mon Feb 27, 2023 5:09 pm
Just received some New Old Stock GFK7514 Badge Fixes from a colleague who worked at Zetland. Apparently he "borrowed" some but inadvertently forgot to return them. :shock:
It is as Tony Cripps engineering drawing posted in this thread (before being removed) shows with a ridge inside part way down the shaft. I wonder if the repro version available now has this ridge inside or not?
PostPosted: Mon Feb 27, 2023 9:19 pm
The one's I got do not have a ridge.
PostPosted: Mon Feb 27, 2023 10:44 pm
PostPosted: Tue Feb 28, 2023 9:02 am
I posted a photo of my New Old Stock GFK7514 Badge Fixes on page 2 of this thread.
Of course they are identical to those Doug has acquired.
