It is currently Sat Jun 21, 2025 1:59 pm
PostPosted: Mon Jan 30, 2023 10:44 am
Hi,
Have fresh 1275 stroked/bored out 40 thou = 1360cc - road/rally spec type engine - built more for torque than bhp. It will only be revved to 6k or more occasionally when driven. Is the cooper s damper ok or is an upgrade required ?
What options do i have that are the physically same size as the standard damper ?
Hint - forget med - I have their damper but because i want to run a Titan belt drive the med damper won't fit and I don't want to stump up again for their whole belt drive/ damper kit.
Thanks
PostPosted: Tue Jan 31, 2023 1:23 pm
I fitted a lightweight Romac pulley but that was nearly 15 years ago:
Still happy with it, very well made.
Not sure if they even make them for minis any more, but you could contact them.
PostPosted: Wed Feb 01, 2023 6:08 am
Oh dear, worry, worry...
HI Rednblackmini
Give SU Midel a ring they have some new old stock MK 2 balance's i bought 2 of them if no luck give me a ring.
Graham Russell
0296302195
