It is currently Thu Jun 26, 2025 11:39 am
 Post subject: Re: MK2 horn location
PostPosted: Sun Jan 29, 2023 12:44 pm
gtogreen1969 wrote:
Here is the full engine bay photo of 2281 showing the slam panel as well.
Was the bonnet lock mechanism unpainted originally?
PostPosted: Sun Jan 29, 2023 1:31 pm
Are you asking about that car or all cars? That car was repainted a few times so I don't know what it had originally.
There are lots of unrestored cars with both painted and unpainted striker plates. Another one of those hard to answer questions.
Going through my pics it looks like the MK1 S was painted and some Mini K and MK2 S were not.
PostPosted: Sun Jan 29, 2023 4:13 pm
I was asking in general, but prompted by that car as the painted strike looked odd. Mine is just plated not painted.
PostPosted: Sun Jan 29, 2023 9:13 pm
Thanks for asking winabbey, I was wondering what to do there.
PostPosted: Mon Jan 30, 2023 9:25 am
winabbey wrote:
gtogreen1969 wrote:
I have only seen about a dozen cars MK2 S with the horn attached to the flitch panel and no holes in the slam panel.
I wonder if the harness needed an extension piece or deconstruction when the horn was relocated, or did the standard main harness reach?
Not sure this is exactly what you mean when you say 'the horn was relocated', but my mini K (early 1969 assembly) has its horn on the lower front subframe channel, as normal, and there is a pair of extension leads in correct colours, linking the wiring harness to the horn.
If you mean that the horn was 'relocated' from the slam panel to the inner guard, the original harness would reach either of those positions without needing extensions, I think?
PostPosted: Mon Jan 30, 2023 12:04 pm
That is the scenario behind my original question. The MK II Series Mini wiring harness was spot taped rather than fully taped or bound. If the horn had more than one possible mounting location did the horn wiring need to be "extracted" from the standard harness with retaping needed?
The Mini parts book specifies this horn extension harness, perhaps used for the Mini K horn location on the subframe Bill mentions above.
PostPosted: Mon Jan 30, 2023 12:40 pm
Yes No extension was needed for the flitch panel mounting.
All models that had a horn under the generator/alternator would have used the extension. Deluxe, Minimatic, Mini K - even the 1971 Cooper S.
Going by the ADO15 on your drawing it looks like it was used also for the 850 which usually had the horn up near the brake master cyl.
PostPosted: Mon Jan 30, 2023 1:22 pm
Just while the horn is up for discussion at the moment :-) mounting bracket bolts and washers/nuts. Plated or painted black from factory?
Bracket is painted black but unsure about the above mentioned.
PostPosted: Mon Jan 30, 2023 1:36 pm
Most small parts came from the suppliier either cast, plated or painted black then during the assembly process they could be painted engine colour, body colour, satin black etc
If you look at the 1968 Brochure for the MK1 S you can see the horn bolts remained plated and not touched up with black paint
PostPosted: Mon Jan 30, 2023 4:27 pm
Thanks
I think I'll leave mine plated at this time as I can't recall any painted black in that area.
PostPosted: Mon Jan 30, 2023 4:37 pm
Nice original engine bay photo. Just needs an 8TR to be perfect. :wink:
PostPosted: Tue Jan 31, 2023 8:51 am
Cheers Winnabbey.
Up Dated photo :-)
PostPosted: Tue Jan 31, 2023 9:32 am
8TR?
PostPosted: Tue Jan 31, 2023 9:40 am
Lucas Australia Voltage Regulator on righthand inner guard panel
PostPosted: Tue Jan 31, 2023 9:42 am
Ohhh, I see... :)
