It is currently Wed Jul 02, 2025 2:33 pm
 Post subject: Distributor Dwell Angle
PostPosted: Thu Aug 25, 2022 5:57 pm
I have a Mk2 Cooper S with AYG0175 distributor and would like to know the points dwell angle.
PostPosted: Thu Aug 25, 2022 6:42 pm
60
PostPosted: Fri Aug 26, 2022 8:51 pm
Thank you gtogreen1969
PostPosted: Mon Aug 29, 2022 4:49 pm
Is there any coralation between the distributor and the type of camshaft used in arriving at 60 degrees?
PostPosted: Mon Aug 29, 2022 5:19 pm
No, The dwell is just the optimum time the points are closed for the coil to build up charge and sufficient rounding of the 90 deg dissy lobes. The specs say 57 to 63 degrees or 14 to 16 thou point gap. Same specs for all models.
PostPosted: Sun Jan 29, 2023 10:31 am
How do you set the dwell angle using a dwell angle analogue meter. I ask because I used a feeler gauge (14 to16 thou) and then a meter and got a completely different reading (not 57 to 63 degrees).
PostPosted: Sun Jan 29, 2023 11:41 am
The ppints gap is what determines the dwell, using a feeler guage is pretty accurate, but obviously you need to have the correct size feeler. 15 thou not 15mm obviously..
The meter is really only a voltmeter with 12v as full scale deflection (fsd). As the pints open and close the meter will go from zero to fsd with each lobe opening the points and powering the coil on and off. Thus at cranking speed the meter will show an average deflection as it tries to keep up with the rapid on/off and therefore will show half or two thirds fsd etc indicating the gap. 15 thou is usually pretty close.
Cheers Dave.
PostPosted: Sun Jan 29, 2023 2:16 pm
It’s worth also checking all four lobes on the distributor cam to make sure they all give the same gap/dwell. If they are worn you’ll get erratic timing and dwell per cylinder
PostPosted: Sun Jan 29, 2023 2:37 pm
They are all fine.
PostPosted: Sun Jan 29, 2023 5:40 pm
This is a common fault with many new Chinese made distributors.
PostPosted: Sun Jan 29, 2023 8:23 pm
Point gap is the "rough" way of setting the dwell. If it is far off though then either it is being set wrong or there is an issue with the distributor. You may be able to crank it over and adjust the dwell by reading the meter instead of the feeler gauge.
At least you don't have to worry about a worn vacuum advance plate causing the dwell time to go up and therefore killing coils.
Too many minis
PostPosted: Mon Jan 30, 2023 9:48 am
Is the dwell meter set for a 4 cylinder engine?
Rod.
______________________________
'63 Morris 850 (Old Secondhand CAR)
PostPosted: Mon Jan 30, 2023 9:45 pm
Yes it is.
PostPosted: Mon Jan 30, 2023 10:33 pm
cooperess wrote:
Yes it is.
And you are reading the correct scale and likely having to multiply it?
I remember reading an MG forum where someone couldn't work out why their dwell was wrong, eventually they realised that they were looking at the 6cyl scale.
Too many minis
PostPosted: Tue Jan 31, 2023 10:22 am
I hope this helps explain.
