It is currently Thu Jun 26, 2025 4:34 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
PostPosted: Thu Sep 15, 2016 6:38 pm
Another great idea.[WHITE SMILING FACE]
I wonder if anyone has tried the brake trick yet?
Sent from my GT-I9305T using Tapatalk
PostPosted: Thu Sep 15, 2016 8:38 pm
I will try this.
Fingers crossed.
PostPosted: Fri Sep 16, 2016 6:33 pm
Bought and made a Jim tool #181 this afternoon for use on another vehicle.
many thanks for sharing. I'll see how it is in the morning.
KB
PostPosted: Fri Sep 16, 2016 6:38 pm
KB
Hopefully Bunnings won't have a return tomorrow; look forward to your findings. 8)
PostPosted: Sat Sep 17, 2016 9:31 am
It's the only way to go - I also used the reverse clamps for holding the carpet in place.
PostPosted: Wed Sep 21, 2016 10:03 am
Wondering if anyone has duplicated my results with the brake pedal feel?
PostPosted: Wed Sep 21, 2016 11:41 am
Yeah it worked for me, I now have a nice high hard pedal
Image[/URL]
PostPosted: Wed Sep 21, 2016 11:44 am
Yeah! I was wondering if I was the only one.
Still not sure how it works?
PostPosted: Tue Jan 17, 2023 7:20 pm
I had a Brake Specialist bleed and flush my Cooper. Result was I had to give brakes 1 pump to get good response. So tried the advice of loading up the pedal overnight. Perfect pedal feel next morning. Thanks for your help with this problem.
PostPosted: Wed Jan 25, 2023 2:03 pm
Fantastic info thanks. I’m heading out to do this now.
Let you know how mine are tomorrow.
PostPosted: Wed Jan 25, 2023 6:04 pm
I used a length of 30x30mm pine cut to length so as not to put too much pressure on the brakes and left for a few hours as I had to fuel it up for the Aussie Day run tomorrow morning. Even after just a few hours it worked! So much better having that higher pedal and not having to pump every time. Thank you. :D
