It is currently Mon Jun 30, 2025 2:34 pm
PostPosted: Fri Dec 30, 2022 8:41 pm
Been a while since I fitted a new radiator cap. Most websites don’t know what a Mini is these days. So it’s useless searching. Currently have a CPC brand 13/90 cap. Tridon seems to list either a CA1390 or CN1390? Any other suggestions on what to use?
PostPosted: Fri Dec 30, 2022 8:48 pm
Is it a long neck or a short neck radiator?
Too many minis
PostPosted: Fri Dec 30, 2022 8:59 pm
This is the current cap.
PostPosted: Fri Dec 30, 2022 9:08 pm
There’s some suggestions here for Tridon caps
viewtopic.php?f=2&t=98289&p=1043597&hilit=Tridon+radiator#p1043597
13psi is 90kpa
PostPosted: Sat Dec 31, 2022 7:45 am
You should firstly determine if the rad is long or short neck. most minis will be long neck but as it only takes a minute to check. measure from the bottom seal area to the top of the neck. long will be about 25mm while a short will be around 19mm.
Cheers Dave.
PostPosted: Sat Dec 31, 2022 11:09 am
Bang on 20mm
PostPosted: Sat Dec 31, 2022 11:12 am
I can’t see anything in the Tridon range that will suit.
PostPosted: Sat Dec 31, 2022 11:26 am
That short-neck cap is p/n GRC1111 at most mini suppliers like Mini Sport SA, Karcraft, Classic Motoring etc.
PostPosted: Sat Dec 31, 2022 11:51 am
Hmmmm. We don’t have anything like that here. Was hoping for Rapeco/Supercrap or Autobarn.
PostPosted: Sat Dec 31, 2022 12:21 pm
On the Classic Motoring website the entry for GRC1111 is crossed to CN1390. This is a Tridon part and your favourite local stores should be able cough one up for you. The CPC brand seems to have an equivalent in 508-13 as well.
PostPosted: Sat Dec 31, 2022 12:36 pm
TRIDON part numbers are prefixed CN for the shorter (31mm) non-recovery cap and CR for the longer (34mm) cap.
Since yours appears to be the shorter style you just choose the release pressure, from 4 psi up to 20 psi.
See here - https://www.tridon.com.au/products/Trid ... iator-caps
If you want to replace your current cap with like for like then CN1390 appears to be the one you want.
https://www.tridon.com.au/products/Trid ... s/2/CN1390
Suggest you print the CN1390 page and take to your auto parts outlet for comparison with whatever brand they have.
PostPosted: Sat Dec 31, 2022 12:41 pm
To be honest the cap you have looks fine, unless someting has broken there is little to go wrong with a non recovery cap.
Cheers Dave.
PostPosted: Sat Dec 31, 2022 12:56 pm
I borrowed this from the Mokewerx website as a comparison of packaging of the two brands.
PostPosted: Sat Dec 31, 2022 1:49 pm
The Tridon website shows incorrect dimensions for the CN1390. That’s what threw me.
Autobarn has the correct dimensions:
https://autobarn.com.au/ab/Autobarn-Cat ... /p/SP05456
PostPosted: Sat Dec 31, 2022 1:50 pm
I think this cap is prob 2003 vintage. So thought I might replace it.
