It is currently Thu Jun 26, 2025 11:33 am
 Post subject: Fuel Tank Cleaning
PostPosted: Wed Dec 28, 2022 12:35 pm
Need to clean the fuel tanks before refitting them to the car.
I was thinking about filling them with molasses & water to remove rust but not sure if molasses will deal with any lacquer build-up if it is present.
Have used POR-15 system in the past with good results, however, I just thought a simpler method would be interesting to try. Some people have used vinegar but molasses would be a lot cheaper I think.
Suggestions would be appreciated.
 Post subject: Re: Fuel Tank Cleaning
PostPosted: Wed Dec 28, 2022 12:50 pm
Using Molasses would surely be like putting sugar in the fuel tank?
PostPosted: Wed Dec 28, 2022 2:38 pm
Bill pm
Bill only one way, Por 15 kit will do 2 mini tanks ,clean and coat inside, Available from a panel paint supplier.
P76
PostPosted: Thu Dec 29, 2022 8:35 am
I've only used the kit, which worked very well. However I did need to run the cleaning solution through a number of times, plus a tub of nuts as an agitator, to remove all the fuel lacquer. I don't think the molasses will break down the lacquer and fuel deposits. Treating the rust was the easy and least time consuming bit.
1966 Mini Deluxe - “Gabby” 34 years under restoration and counting...
1970 MGBGT
1959 MGA
