It is currently Thu Jun 26, 2025 7:26 am
PostPosted: Mon Nov 28, 2022 8:52 am
I have to replace the rear subframe bushes and have a set of Mini Sport black poly type that the previous owner must have bought but never fitted. Should I just use these, or buy a rubber set?
PostPosted: Mon Nov 28, 2022 9:09 am
These days I would use poly. As the quality of 99% of rubber is rubbish and cracks up prematurely.
Ditto front lower arm rubber bushes.
PostPosted: Mon Nov 28, 2022 10:06 am
Thanks Dr. That saves me a few $ too.
I see you’ve got a Peak ignition fitted too. I couldn’t believe the difference it made to my setup. Can’t rate them highly enough, but I believe they’ve gone out of them now?
PostPosted: Mon Nov 28, 2022 5:31 pm
I believe so. :?
Lomin (Lindsay Seibler) might update if there's any change likely.
PostPosted: Mon Nov 28, 2022 6:48 pm
I would use the rubber mine had the poly in it and they COMPLETELY disintergrated .
PostPosted: Mon Nov 28, 2022 10:38 pm
what about solid bushes?
PostPosted: Tue Nov 29, 2022 1:05 pm
If they were the old red poly from yesteryear I would agree, they were crap.
My steady bar ones did the same.
But recent black poly bushes seem fine.
PostPosted: Wed Nov 30, 2022 6:38 pm
Doc they were purple ? From memory.
PostPosted: Thu Dec 01, 2022 9:15 am
I installed these and can't complain. holding up well.
Whiteline W92135
https://automotivesuperstore.com.au/whi ... XPzXEqXPZc
1974 Moke - 998cc
Users browsing this forum: acarseldine and 48 guests
