It is currently Thu Jun 26, 2025 9:08 pm
 Post subject: Re-keying A Lock
PostPosted: Sat May 07, 2016 4:14 pm
Enthused by other posts on changing to key in a lock barrel I decided to attack my door lock to make it the same as the Ignition and Boot lock.
1. Remove the door handle from the car.
2. Remove the collar from the handle. If you have the key, turn it till the square locking pin is inside the handle and the collar will slide off. If you don't have the key, you may have to file the Square Locking pin down till you can slide the collar off.
3. Knock out the pin that holds the Lock Barrel in. I filed the point off a suitably sized nail.
4. This is what you should now have.
5. Look at the lock barrel and you will see that all of the lock Tabs (don't know what their real name is) are being pushed out of the barrel by the springs.
6. This is how the barrel looks with the original key in. All of the Tabs are flush with both sides of the barrel.
7. Now insert the key that you want the barrel to match. Here is my Ignition Key inserted into the Door Barrel. Note that two of the Tabs poke out one side and one on the other.
8. You now need to change the Tabs that poke out either side of the barrel with ones that don't. The best that I can work out is that there are three sizes of Tabs. Where the line is in this comparison there is a 2.5mm one on the left, then 3.5 and then 4.5mm. This is the length of the solid part to the cut-out that the key slides into.
9. Without the key in push one of the Tabs out that was not flush with the Barrel from the opposite side that the little springs are on, this will be the side that the smooth side of the key is on.
10. Replace this Tab with a different one that has a shorter or longer slot in it and refit the key. You will see if you have gone the right way with the different Tab. You might have to steal Tabs from other spare locks to get the ones that you need. Don't lose the tiny springs when you are changing the Tabs
11. This is my Barrel with the Ignition key fitted and the "spare" original Tabs that had to be replaced with the correct size ones for this key. All of the Tabs are now flush with the Barrel.
12. Refit the Barrel into the door handle and replace the locating pin.
Refit the door handle to your car and now the lock should match the other ones.
 Post subject: Re: Re-keying A Lock
PostPosted: Sat May 07, 2016 7:48 pm
Good job.
I took a stack of photos ages ago when I did the locks on my clubman, with the intention of making a how to.
Never got round to posting it all up with instruction... Dont need to now :) As the process is essentially the same.
Yes there are 3 sizes as you have stated, and just got to be careful about loosing those little springs that hold the wafers out.
PostPosted: Sun May 08, 2016 7:17 pm
very nice it is a very easy job
PostPosted: Tue Oct 11, 2022 7:57 pm
Thanks Phil 850 for this great how-to. I bought some of those excellent re-pro stainless door handles and they came with a boot lock barrel as well , same as [ viewtopic.php?p=1065376#p1065376 ]. I really wanted to have only one key for all, so purchased another ignition switch complete and another barrel. I then used the information on this post and hey presto - I have a matching set of locks.
PostPosted: Tue Oct 11, 2022 8:20 pm
Glad to have been of assistance ausdino.
PostPosted: Tue Oct 11, 2022 9:32 pm
Much appreciated, saved me a trip to the locksmith.
PostPosted: Tue Oct 11, 2022 11:56 pm
Why isn't this in the how to section?
PostPosted: Wed Oct 12, 2022 7:44 am
ausdino:- Did you notice that the reproduction locks are not the same as the original locks, in as much as the barrel when fitted stands roughly 1 mm proud of the door handle.
PostPosted: Wed Oct 12, 2022 10:25 am
Great post and will come in handy very soon, thanks
PostPosted: Wed Oct 12, 2022 4:28 pm
PM sent.
Users browsing this forum: cgo and 76 guests
