It is currently Fri Jun 27, 2025 1:32 pm
 Post subject: what needles and springs
PostPosted: Sun Sep 04, 2022 8:18 pm
Hi fellas what dprings and needles would people recommend for a set of twin sus with a 1275 40 thou over, 266 GR cam and extractors?
1964 smooth roof panel van
1967 Mk 1 X-Police cooper s
1970 mini k
1975 leyland
PostPosted: Sun Sep 04, 2022 9:50 pm
If twin HS2's then probably just the standard Red Springs and M needles. Change to AH2 needles if it needs to be a bit richer.
If you have twin HS4's like the SPO41 then your probably looking at Blue Springs and CP4 needles. Change to No 7 or No 6 needles if it needs to be a bit leaner. Here is a comparison of the needles
Not sure about the floating type needle.
PostPosted: Mon Sep 05, 2022 9:12 am
I have a 1310 with 2x 1-1/2 SUs, MED head and GR's 266SS cam.
I experimented with lots of carb spring/needle combos on my dyno.
The red springs worked ok, but didn't allow full opening of the carbs, but blues were great in that respect.
I'm using blue springs and CP4's as gtogreen suggested, but they are modified quite a bit from station 4 and up, but you may not have to do this if you don't have much cylinder head on it.
It would be a good starting point if you have twin 1-1/2" carbs.
PostPosted: Mon Sep 05, 2022 8:11 pm
sorry i thjought i specified. They are 1 1/4 sus
1970 mini k
1975 leyland
PostPosted: Tue Sep 06, 2022 7:18 pm
Red springs and m needles , initially tried ah2 needles m was better .
PostPosted: Tue Sep 06, 2022 8:04 pm
Thanks for the input fwllas appreciated
1970 mini k
1975 leyland
Users browsing this forum: No registered users and 68 guests
