The picture below shows the steering column diameters used at various times. Note, the Models shown are "first used on" and can also be found on other models not listed. The Parts books are somewhat lacking in detail with the part numbers. Essentially, the column outer tubes were made from 1 1/8 tube swaged out at the top for the top bush (early), or in later years, made from 1 1/4" tube swaged in to 1 1/8 at the bottom end for the bush. The black clamp can be one of two types with hole diameters to suit the tube. Regards Tony.
