It is currently Thu Jun 26, 2025 5:51 pm
 Post subject: Speedo Dash Lights
PostPosted: Wed Jul 20, 2022 9:58 pm
Have an Aussie round nose with central speedo.
The speedo is hard to read at night - odometre and fuel gauge are OK.
Should I be chasing a fault like low voltage, is it my ageing eyes or is it standard?
Globes are new 2.2 watts.
Any ideas?
Last edited by IndigoBlueCooperS on Thu Jul 21, 2022 5:46 pm, edited 1 time in total.
 Post subject: Re: Seedo Dash Lights
PostPosted: Thu Jul 21, 2022 9:35 am
you can buy LED bulbs not sure where to buy them, Some of the minis in the hunter morris club have fitted them. The forum will let you know where to buy them.
Allen
PostPosted: Thu Jul 21, 2022 11:54 am
Are the little cardboard tubes in place
PostPosted: Thu Jul 21, 2022 1:01 pm
Yes, tubes in place but from memory they are only for the warning lights.
Also made sure all the surfaces inside were clean.
PostPosted: Thu Jul 21, 2022 1:28 pm
Mine is pretty dull too. There's no direct path from the bulb to the speedo face, so it needs to be bright enough to bounce off the casing and make it to the front of the speedo face.
As mentioned above you can get the GLB987 / E10 bulbs in LED - e.g.
https://www.classiccarleds.co.uk/produc ... 3344560157
PostPosted: Thu Jul 21, 2022 2:45 pm
Timmy I fitted some of those and they were useless in my Mini gauges. I went back to originals. I think the bulb tubes are too long for LEDs.
(Edit) I'm talking about the oil and temp gauges.
But a mate has them in a Midget speedo and work fine.. :-\
Last edited by drmini in aust on Thu Jul 21, 2022 9:08 pm, edited 1 time in total.
PostPosted: Thu Jul 21, 2022 5:45 pm
Checking the speedo again, the tubes are only for the warning lights, so the LED's my be OK for the dash illumination lights.
I think I will give the LED's a go as per Timmy's comment. Might try them in the oil and temp gauge as well, but these do have a bit of a tube.
 Post subject: Re: Speedo Dash Lights
PostPosted: Thu Jul 21, 2022 5:56 pm
Just remember the ignition warning light needs the load of the incandescent bulb, so you either keep it as an original bulb or add a resistor to simulate the bulb
PostPosted: Thu Jul 21, 2022 7:51 pm
Thanks Timmy, but I am only going to change the dash illumination lights. All the warning lights are spot on.
PostPosted: Thu Jul 21, 2022 8:06 pm
I think the brightness of the speedo illumination does rely a bit on the condition of the inside of the speedo - if its grubby or dusty there will be less light refracted around to make it brighter? maybe?
PostPosted: Thu Jul 21, 2022 10:11 pm
Have rebuilt a couple of speedos and tachos recently and the original inside of the metal surrounds are painted with some areas of stark white and others of duck-egg blue. I guess these colours are meant to reflect less yellow light but my eyes don't seem to register any improvement either.
PostPosted: Thu Jul 21, 2022 10:52 pm
I will double check the cleanliness when I change the gearing over next week, but pretty sure it was all good with no rust or paint deterioration.
PostPosted: Fri Jul 22, 2022 8:58 am
I've still got a few LEDs I will put 2 in a borrowed speedo for test.
Can't get into mine without pulling the 45 Dellorto off first.
Edit
LEDs I have are too long when in original red/white wire bulb holder.
18mm overall.
Distance to back of dial is only 16mm. Mini K speedo.
But light distribution looks good when held in place. I need shorter bulbs.....
I've ordered some from eBay won't get here for 6 weeks. Must be coming via Russia...! Hope they fit...
https://www.ebay.com.au/itm/254421913339
PostPosted: Sat Jul 23, 2022 5:47 pm
I recently ordered these https://www.ebay.com.au/itm/272356395596 - just installed today but haven't had a chance to see them in the dark yet. Took just over a week to arrive from the UK.
1964 MORRIS 850 - POST ZOMBIE APOCALYPSE CAFE RACER INSPIRED.
https://spotify.link/D0P4KtIP2yb
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
1.3:1 Roller tip rockers
Stupid high CR
PostPosted: Sat Jul 23, 2022 6:32 pm
I was going to order a couple of these. When will you have a chance to test these in the dark?
Users browsing this forum: Barkfast and 91 guests
