It is currently Fri Jun 27, 2025 11:55 pm
PostPosted: Fri May 27, 2022 2:01 pm
At least three pattern types of vinyl was used to make the headlining for Australian assembled Minis. I'm trying to establish the various styles and the dates they were used in production.
All models of Mini used the same headlining in the same period, meaning there was no difference for a Cooper S versus Mini K versus Mini Matic, etc.
I'm told type 1 (below) was used originally and then Type 2 replaced it, sometime in the late 1960's, but this is what needs confirmation.
Type 3 appeared in the 1970's during the Clubman / Leyland Mini era.
My August 1970 Cooper S has Type 2 fitted.
What do you think?
PostPosted: Fri May 27, 2022 4:44 pm
My 1969 Mk2 looks different again.
PostPosted: Fri May 27, 2022 6:22 pm
Thanks for the image.
Part of this discussion is to pinpoint the factory trims versus aftermarket trim. Not suggesting yours is a later aftermarket type by the way. I don't know but learning from this chat.
Be aware I posted on the Ausmini FB Group and there's been lots of responses.
https://www.facebook.com/groups/2503682 ... 1879920567
PostPosted: Sat May 28, 2022 9:23 am
Not being in the 21st century, I am unable to use FB Group.
PostPosted: Sat May 28, 2022 10:36 am
Hood lining from my 3/70 S.
PostPosted: Sat May 28, 2022 12:47 pm
ausdino, your looks the same as mine but mine needs a good clean.
PostPosted: Sat May 28, 2022 2:22 pm
So does mine, it has been sitting folded up since 1983.
PostPosted: Tue Jun 07, 2022 10:18 am
My late 68 build MK1 S has type 1 headliner pattern.
Miniron
68 build Mk1 Cooper S
PostPosted: Wed Jun 22, 2022 8:43 pm
A sample of the closest pattern to type 2 has arrived and shown below. The manufacturer says the embossing can be adjusted so it is less pronounced and so more like the original.
What do people think?
PostPosted: Wed Jun 22, 2022 9:13 pm
I like 'B' but needs to be modded.
PostPosted: Wed Jun 22, 2022 9:34 pm
I wonder if the original was closer to the new sample but has “stretched “ over time?
PostPosted: Wed Jun 22, 2022 10:32 pm
You could be right. But the new one has too many fat bits.
PostPosted: Fri Jun 24, 2022 1:05 am
Looks like too me that when the vinyl material has gone through the heated embossed drum roller that they have applied to much heat and pressure, hence the over embossed look.
PostPosted: Wed Jul 06, 2022 3:30 pm
This is out of my 67, do you think this would be orignal
PostPosted: Wed Jul 06, 2022 4:52 pm
No
