It is currently Sun Jun 29, 2025 5:11 am
PostPosted: Fri Jun 17, 2022 7:06 pm
There seem to be no outlets for the female connector for the 13H7779 part, at least not on google. I am trying get one, can any one help?
PostPosted: Sat Jun 18, 2022 10:45 pm
Not quite sure what you are after.
Is it this part of the connector block that joins the blinker switch to the main harness?
If it is, these were mostly used in clubman minis.
Mk2 S and mini K used a 6-gang joiner like this:
The 13H7779 blinker switch comes with the clubman terminal block. For originality, the switch stalk is almost identical but to fit to a Mk2S or K, the wires need to end with bullet terminals which push into the red 6-gang joiner.
Some of the wires used to control high/low beam at the blinker switch have been cut by the factory for S and K application.
PostPosted: Sat Jun 18, 2022 11:07 pm
That's the one Bill = the top black plastic one.
PostPosted: Sun Jun 19, 2022 10:12 am
Send me an email or pm if you still want it.
These were not used on Mk2 S - they had the red sleeve joiners. The wiring harness should have the leads for the blinker unit ending in bullet terminals - not female spade connectors which were used in clubman harnesses.
Users browsing this forum: No registered users and 119 guests
