It is currently Wed Jul 02, 2025 8:22 am
PostPosted: Thu Jun 02, 2022 10:03 am
Hi All,
I am looking at getting a set of minilites (https://minisport.com.au/10x45-genuine-minilite-alloy-rim-set-of-4-s-offset) but unsure whether to go for the 4.5" or 5".
What size tyres fit these? 145R10s or 165R10s or both?
Will the "S" offsets with disc brakes fit under the guards without flares for both sizes?
If I have the factory style flares (https://minisport.com.au/mini-original-factory-flare-set-leyland-type-salsagt), will the wheels look too small?
TIA
PostPosted: Thu Jun 02, 2022 1:12 pm
4.5” wide rims will take 145 or 165 wide tyres
4.5” with the “S” offset will fit nicely without flares
If you have flares you’d probably want 5” and an offset of approximately 15mm
PostPosted: Thu Jun 02, 2022 4:01 pm
Just for comparison, this is a magnesium TechDel Minilite (from the 70s I think). Its probably a 5 or 6 inch wheel going by the 165 (Goodyear G800 IIRC) tyre fitted.
Here it is fitted to a Mate’s 65 S that I was babysitting for a while.
The wheels in your link look like the ones Minilite refers to as “FIA offset”. The 4.5” version with 165 tyres (A008s) will juuuust fit under standard S arches (ie no flairs). The tread is covered while the sidewalls stick out ..but not enough to upset NSW rego authorities... :wink:
Cheers, Ian
PostPosted: Thu Jun 02, 2022 5:31 pm
Depending on the disc setup, you may need to shave the caliper a little as well. I needed to take about 5mm off the corner of the bleed housing with my 7.5 discs. These are original ROH that just fit under the guards with 165 yokos. Not an issue as not structural and not close to the thread etc.
Add the silver 'S' side trim and there isnt any poke at all.
1966 Mini Deluxe - “Gabby” 34 years under restoration and counting...
1970 MGBGT
1959 MGA
PostPosted: Thu Jun 02, 2022 6:57 pm
..... a couple more comparisons.
Firstly a 4.5” FIA offset Minilite fitted to my Traveller; which has an S front end so the tyre arch relationship will be exactly the same as for an S.
And secondly, a Minilite with A008 alongside a factory LS alloy and Bridgestone... The 008s stick out fractionally more than the Bridgestones ... but its 4/5ths the square root of.......
The Minilites have a touch more clearance than the LSs (which need a small shim) ssshhh 8)
Cheers, Ian
