It is currently Tue Jul 08, 2025 3:38 pm
 Post subject: Winch attachment points
PostPosted: Tue May 17, 2022 8:49 pm
Hello all,
I need to pull a 1972 mini onto a trailer using the trailer mounted winch. Is there a particular section of the rear subframe that a chain or flat strap may wrap around to use as an anchor point to hook onto?
Any advice from someone who has done this without incident welcomed.
PostPosted: Tue May 17, 2022 9:12 pm
a length of chain and two d shackles one on each tie rod end and pull from the middle of the chain :)
PostPosted: Tue May 17, 2022 10:33 pm
I note that Robert asks about a rear subframe mount.....
If your intending to tow said trailer then you need to load the Mini front first. Having the load biased behind the trailer wheels is an invitation to interesting road dynamics.... BTDT :shock:
Cheers, Ian
PostPosted: Fri May 20, 2022 8:23 pm
you can thread a flat strap through the vertical "webs" in the rear subframe where the rubber cones/hydro bags are
