It is currently Sat Jun 28, 2025 9:09 pm
PostPosted: Sun Apr 10, 2022 2:48 pm
Was the soundproofing behind the dash cards in 2 pieces or several odd shapes to go around holes and knobby bits?
Have carefully stored the originals 'somewhere safe' and can't remember what the they looked like.
I know I have to allow for the oval binnacle to go against the metal firewall.
PostPosted: Mon Apr 11, 2022 7:08 pm
Hi Bill, Something like these ? Seem to fit, could not find another home for them.
PostPosted: Mon Apr 11, 2022 9:19 pm
Found some more. It appears two pieces go to the LHS , one to the right - plus one each side of the first picture above. These pieces haven't seen the light of day for nearly 40 years.....its time to make a concerted effort to restore this car.
PostPosted: Tue Apr 12, 2022 12:13 pm
Thanks Peter.
The trim card backing gives me a scale, too.
Might be hard to remember but does the felt cover the large air vent hole in front of driver?
PostPosted: Tue Apr 12, 2022 4:15 pm
Don't think so, or I have lost a piece. Should only be (from memory) the piece around the binnacle and the far rhs on this side of the car, will check later.
PostPosted: Tue Apr 12, 2022 5:31 pm
A search on Ausmini found a comment that there were 4 pieces - 2 each side - in the dash soundproofing, although no images.
I think I'll just improvise using pieces as per your photo.
Thanks for the reply.
PostPosted: Tue Apr 12, 2022 5:59 pm
There's also some images of the dash sound proofing and various other bits installed here:
http://mk1-forum.net/viewtopic.php?t=30642
Paul.
1970 Morris Mini K
PostPosted: Tue Apr 12, 2022 9:05 pm
Photos taken whilst replacing the millboard / fibreboard backing - looks to be 2 x pieces (for both L & R sides) + another section immediately to the left (& right) of the nacelle. Hopefully can accompany what Peter has shared above.
PostPosted: Tue Apr 12, 2022 10:03 pm
Edit: Just re-checked again. Two each side. Car is upside down on spit atm and I played tetris with these pieces. Somehow I must have obtained an extra. Sorry if any confusion.
PostPosted: Tue Apr 12, 2022 11:24 pm
Would you have a picture of the drivers side as well?
PostPosted: Wed Apr 13, 2022 8:58 am
Starting to make sense of it: Hinesy1275 looks like a Mk1 where the felt and panel go behind the binnacle. I think the Mk2 has the felt and panels cut around the binnacle so it seats hard against the firewall.
PostPosted: Wed Apr 13, 2022 9:59 am
Sorry Peter - no photos of driver's side... As Bill has alluded layout may be a little different for Mk 2 as photos above are of a late Mk 1.
