It is currently Fri Jun 27, 2025 11:57 am
PostPosted: Fri Mar 11, 2022 1:43 pm
Hello - Can anyone tell me if the above model Mini Cooper had an air box fitted to the twin 1 1/2 SU carbs or no air box as shown in the attached photo? Cheers
PostPosted: Fri Mar 11, 2022 1:50 pm
The 1.5” carbs weren’t fitted until 1970 with SPO41. Earlier police spec cars had the standard HS2 carbs
When they were fitted, the 1.5” carbs were fitted with Ramflo filters like you’ve got there
More details here
viewtopic.php?f=2&t=91761&p=993812
PostPosted: Fri Mar 11, 2022 3:38 pm
What numbers on the I'd tags on the carbs ?
PostPosted: Fri Mar 11, 2022 4:42 pm
Until August 1970 all Cooper S supplied to NSW Police were stock standard showroom models from a performance perspective, so Mark 1's like yours had the normal air cleaner with 1 1/4"SU's.
PostPosted: Fri Mar 11, 2022 7:19 pm
Thanks for the helpful information, cheers
PostPosted: Sat Mar 12, 2022 10:35 am
Can I suggest you avoid using foam filters unless they are using oil in the foam to help trap dust. The early Ramflo filters, including the set-up on SPO41 police cars, used the foam dry.
I ruined 2 motors over a few years due to grit/dust getting in. Changed back to paper filters years ago.
PostPosted: Sat Mar 12, 2022 1:04 pm
Completely agree Bill. So called performance filters are a total waste of time. Not to mention the poor filtration.
Paper filters are by far a better product and the standard filter housings are also the way to go.
Cheers Dave.
PostPosted: Sat Mar 12, 2022 2:42 pm
I’ve found the modern foam elements from unifilter have been really good. They come pre oiled and there’s no sign of anything getting through them
PostPosted: Sat Mar 12, 2022 4:29 pm
How recent are the modern ones, Timmy?
Cheers Dave.
PostPosted: Sat Mar 12, 2022 6:07 pm
If you mean the green sock type of Unifilter with oil, I understand they are excellent - don't have experience of them, though.
I am concerned that the Ramflo filters that were fitted to police Ss and were meant to be washed out and used dry are the same as the current Ramflo offering. There is a website for Ramflo that offers replacement foam filter elements, but I can't find any reference to oil being used with the foam.
I am concerned that some people, used to modern cars, don't understand what goes into supplying clean air to an engine.
If using HS2 (1 1/4 inch) standard Cooper S SUs, use the standard air box and filters.
PostPosted: Sat Mar 12, 2022 6:28 pm
These are from the last year or so. They are ramflo compatible and a straight swap
https://www.uniflow.com.au/contents/en-us/d141.html
PostPosted: Sun Mar 13, 2022 10:38 am
So does that mean that you use the standard Ramflo foam element and place an oiled cover over it, and run the 2 together?
PostPosted: Sun Mar 13, 2022 11:34 am
No the unifilter oiled foam element replaces the ramflo foam. I’ve been running one on my Dellorto and a pair on HS2 and there’s been no sign of anything making it through the filter
PostPosted: Tue Apr 12, 2022 4:34 pm
This is on the side of the Ram Flo Filter Box.
PostPosted: Sat Dec 03, 2022 12:21 pm
Will 2 of these fit on my twin HS4's
https://minisport.com.au/mini-moke-panc ... fset-mount
