It is currently Fri Jun 27, 2025 11:50 pm
PostPosted: Thu Mar 10, 2022 4:41 pm
This is the photo that cgo posted, of the support strip fitted UNDER the body seam. When fitted this way, are there any little pockets formed that could be a mud/rust trap - esp. where it meets the beaver panel?
PostPosted: Thu Mar 10, 2022 10:19 pm
Probably somewhere between 3/70 (mine) and 7/70. See if others chime in
PostPosted: Fri Mar 11, 2022 6:44 pm
Good point Bill, mine seems all good. Checked both sides. Maybe that's why they changed the fitment procedure. Technically, I would have less flare base to wheel clearance and the flares would be sitting lower on the body.
PostPosted: Fri Mar 11, 2022 7:09 pm
Thanks, Peter.
Your photo of LHS backing strip doesn't seem to show any mud pockets. No more than usual, at least. Must have been shadows on the RH photo.
