It is currently Sat Jun 21, 2025 2:20 am
 Post subject: Spider drive adapter
PostPosted: Wed Jun 17, 2015 5:43 pm
where can i get one in aus?
anyone make one local?
all i can find is uk places
 Post subject: Re: Spider drive adapter
PostPosted: Wed Jun 17, 2015 6:01 pm
If you're handy and have access to a TIG, a grinder, and a dremel you can easily grind a suitably scrounged piece of metal to fit snug in the end of the cam. Then TIG it in being careful not to overheat the cam. Using whatever method you like - Find the centre of the cam on the plate and use this to scribe a line that effectively splits the end of the cam in two. Then using this line as a reference you can layout the cutout for a spade drive and cut it out very carefully with the dremel.
PostPosted: Wed Jun 17, 2015 6:10 pm
dr mini has them made and they're sold through Mini King and others. I have one of his in my cam, it just sits in place, not welded
Various Australian suppliers have them. Here's a couple, but also check the other businesses that may be closer to you (suggest you add your location to your user profile :wink: ).
http://www.classicmotoring.net.au/cmos/ ... ts_id=1239
http://minikingdomonline.com.au/product ... adapter-2/ or http://minikingdomonline.com.au/product ... e-adapter/
http://minisport.com.au/ This was to be a link to the part in the Minisport shop but I can't find it at the moment.
Other businesses to try are here - viewtopic.php?f=41&t=83593
PostPosted: Wed Jun 17, 2015 6:21 pm
Forgot to mention; you are no doubt aware there are two types - one for a star drive oil pump and another for spade drive pump?
PostPosted: Wed Jun 17, 2015 6:23 pm
I have no oil pump yet, fresh rebuild with a re13 cam i got from minirich. any advantage to either pump?
PostPosted: Wed Jun 17, 2015 6:40 pm
Not my area of expertise. I'll leave it to Doc and others.
I see Mini Rich has an adapter - http://www.minirichs.com/engine/17138/1 ... -spade-dve
PostPosted: Wed Jun 17, 2015 6:49 pm
Well the laser cut steel `slot drive' spiders came about because the original splined bore ones stopped being made years ago.
To set up and cut splines in a limited quantity was cost prohibitive, whether broached or wire-cut.
Slot drive pumps are standard on the A+ (UK) motors, they are a later design. Cheap to buy from all the usual outlets here or UK. Description is `1275A+ slot drive oil pump'.
Here's a pic with the spider on it-
[edit] you can also machine down the slot drive adaptor to permanently convert a pin drive cam.
Like this- note these 3 ears still need to be chamfered then TIG welded in:
Last edited by drmini in aust on Thu Jun 18, 2015 2:07 pm, edited 1 time in total.
PostPosted: Wed Jun 17, 2015 6:53 pm
The star drive pump is the pump that was used with the "spider drive" cam with a little adaptor. You could also modify your cam as I described above to run a spade drive pump.
I've seen good and bad star and spade drive pumps from the same manufacturers - I'd advise checking the pump to make sure it is serviceable before fitting. Therefore best bet it to buy from an Australian retailer incase you need to chase up a warranty/exchange.
PostPosted: Wed Jun 17, 2015 10:38 pm
One problem with current steel backed pumps either spade/slot drive, or the splined spider drive is the chamfer on the body is too small.
It can foul the blocks recess's radius and prevent the gasket sealing.
Cure = grind or sand a bigger chamfer on it before fitting. :wink:
PostPosted: Thu Feb 17, 2022 7:07 pm
Does anyone know where I might be able to get a spider drive to slot drive oil pump adapter these days?
PostPosted: Thu Feb 17, 2022 7:28 pm
One in stock here according to the website
https://classicmotoring.net.au/oil-pump ... p-adaptor/
PostPosted: Thu Feb 17, 2022 7:39 pm
Thanks Timmy - I had searched all the usual sites including theirs but must have missed this somehow. Problem solved. Operator error as usual!
Matt
PostPosted: Sat May 28, 2022 4:09 pm
I'm back here now..
Message me and I will post.
Kevin
PostPosted: Mon May 30, 2022 7:56 am
Good to see Kevin back.
