It is currently Sun Jul 06, 2025 9:00 am
 Post subject: Camshafts - HELP!
PostPosted: Sat Jan 01, 2022 12:40 pm
I'm sure there is no such thing as the perfect camshaft - no doubt i am over thinking the entire process.
Im building a 1098 +0.040 with GR Flat top pistons & 12G202 head (with work) - just aiming to make a torquey Fast road engine.
i keep bouncing between the idea of a Kent 266 or 276 & KAD100.
I'd like to hear feedback from anyone that has used any of these - pros & cons.
Any other options also... Ideally I need to be able to just order something ASAP rather than waiting for one to be ground.
Thanks mini'ers
1964 MORRIS 850 - POST ZOMBIE APOCALYPSE CAFE RACER INSPIRED.
https://spotify.link/D0P4KtIP2yb
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
1.3:1 Roller tip rockers
Stupid high CR
 Post subject: Re: Camshafts - HELP!
PostPosted: Sat Jan 01, 2022 8:24 pm
talk to GR about his 266 camshaft, i have this in my Mini K & it works very well
PostPosted: Sat Jan 01, 2022 9:12 pm
Hi I have had both the Kent 266 and Graham russells 266ss cams. I have one in each of my motors but haven't been driven for a good while. They are both great cams for power pretty much through all revs. You don't have that lumpy idle either so people won't really know you have a "cam" so to speak. I find both of these cams fairly similar but I think the 266ss which I believe is Graham russells is slightly better for power. That's my 20 cents worth. Others may pitch in for a cleR picture. As I said its been a while since I not only drove these motors but to compare them both.
1964 smooth roof panel van
1967 Mk 1 X-Police cooper s
1970 mini k
1975 leyland
Users browsing this forum: 748rum and 84 guests
