It is currently Sat Jun 28, 2025 1:15 pm
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
 Post subject: Re: 4post hoist
PostPosted: Sat Aug 14, 2021 6:04 am
2lateagain wrote:
I am not knocking the idea of this. I see that removing and replacing the posts over the bolts in the floor will eventually lead to the threads of the bolts being damaged, then you will not be able to securely hold it to the floor and it will have to be leveled each time you put it back in place. You will also have two posts stored that are sitting on a relatively small base each weighing some 145kgs each that should they get knocked are going to cause some damage if they fall, they would need to be secured to stop them falling. The 3 inch wheels that the posts are moved on would need a perfectly flat clean floor as if they get caught on a small stone/object and stop suddenly then you are trying to control a lot of weight plus the bolts will still be in the floor and they may be some other cause of a problem. As I say this is just my opinion and I am not trying to cause any arguments. I would think it is just as easy to have the posts in place all the time, then it will ready when you need it.
Graham
Spot on observations for me and concerns that I share. The benefit of this one is the much lower height than some others, that may be more appropriate for low ceiling height garages.
I’d be looking to keep something in place pretty much all of the time ideally, but it’d be a nice option to pack it away for a while once the project cars are done (are they ever truly done though!? :lol: )
PostPosted: Sat Aug 14, 2021 7:36 am
The other thing that comes to mind is there has to be some sort of very good valve that controls the flow of oil to each of the hydraulic cylinders, you do not need one getting more oil than the other when lifting nor one letting more oil out when lowering, this is why I like the cables, they make a positive move up or down at the same rate.
No the use of hoists seems to be never ending, our one has had special platforms made so the ride on mower can be worked on same as cars.
Graham
1974 Leyland Clubman
Lots of good machines
Of all the things I have lost, I miss my mind the most.
PostPosted: Sat Aug 14, 2021 9:21 am
The floor in your shed may not be strong enough for a hoist, particularly a 2 post, you should check with the hoist provider as to their recommendations for floor construction.
Cheers Dave.
PostPosted: Sat Aug 14, 2021 9:32 am
You could always, cut a slit in the concrete and bury the baseplate.
For the removable half-height hoist, bolts can be used into the bases so that you end up with a nice flat floor...
PostPosted: Sat Aug 14, 2021 11:46 am
timmy201 wrote:
AJ wrote:
timmy201 wrote:
How do you guys find the bottom base plate between the posts? Obviously it means you can lift the car higher, but is it annoying being on the floor?
Baseplate is fine , no problem at all
Thanks, I guess if you had a narrow garage it'd make it harder to push around an engine crane, but with a wider garage it'd be fine
What size is your shed? Looks like a great size
Shed is 12 x 7 , could do with a bigger one :D
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
PostPosted: Sun Aug 15, 2021 11:25 am
Baseplate is a cover for the cables and hydraulic pipe only , which would not be long enough if recessed into concrete :D
1965 Morris 850
1977 Leyland LS
PostPosted: Sun Aug 15, 2021 11:27 am
OK lay some thick tiles, boards, whatever to build up the floor to height of the baseplate cover :idea:
Users browsing this forum: 1071 S and 103 guests
