It is currently Sun Jun 29, 2025 7:45 am
PostPosted: Mon Jul 26, 2021 9:28 am
Hello
What is everyone using for a centre cap on the Contessa Wheels
Mine have a 62mm hole and i cant seem for find anything on the internet this size
I did have Performance brand caps that were 60mm but they were siliconed in and i ended up loosing one
Cant even find one of those on the Internet
All help appreciated
Thanks
Marc GundyGuy
1970 MK2 Cooper S
PostPosted: Mon Jul 26, 2021 12:15 pm
Marc,
Was able to find 3 of these on Facebook Marketplace. Had been looking for quite a while, I guess a waiting game if you want these. Hole size in rim is 65mm, cap clip diameter is about 67mm.
A suggestion from Ausmini Facebook was to use Performance brand caps, like one in your photo, from GT Wheels.https://gtwheels.com.au/search?q=wheel+caps
Good luck.
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1963 Triumph Spitfire
1982 RX-7 Series 2
PostPosted: Mon Jul 26, 2021 1:05 pm
Does the wheel have a lip on the outer edge to retain clip in style caps? Or do you need push through caps?
PostPosted: Mon Jul 26, 2021 3:01 pm
The hole is 62mm
No idea how the original cap mounted
The ones that were on it were urethaned in
PW004 is the part number
1970 MK2 Cooper S
PostPosted: Mon Jul 26, 2021 4:22 pm
So do they have a lip to hold in the cap like on the left side of the picture, or are they the same diameter all the way through like the right photo?
If you can find exact dimensions of the caps you need there are literally thousands of them on eBay
PostPosted: Mon Jul 26, 2021 5:18 pm
Lundy is lucky in that all his are the same size. My "set" has 3 different size centres and some have lips and some don't.....
Cheers, Ian
PostPosted: Mon Jul 26, 2021 7:35 pm
Not all Contessas were sold by ROH as such.
I bought a set years ago that had 'Cheviot' metal caps, screwed onto the outside with 4 screws.
I still have 3 or 4 caps. Chrome with a black face.
PostPosted: Tue Jul 27, 2021 12:25 pm
The bores are straight
There are a lot of flat type centre caps on the internet but i need ones that have a dish to them to clear the front drive shaft nut
I wonder why the centre sizes vary
1970 MK2 Cooper S
PostPosted: Tue Jul 27, 2021 12:55 pm
Maybe different manufacturers as Kev suggests. Anyone know if ROH and Cheviot were related?? Did ROH run their own foundries or did they contract out???
The only Oz Minilite copies I ever bought new (from ROH) were labelled "Contestas" .... according to the artwork on the box.
Cheers, Ian
PostPosted: Tue Jul 27, 2021 1:54 pm
ROH always called them Contestas :D
PostPosted: Wed Jul 28, 2021 12:01 pm
How about these?
http://www.minispares.com/product/Class ... o%20search
PostPosted: Thu Jul 29, 2021 4:04 pm
The guy I bought my wheels from had made some from cheap and cheerful stainless camping cups. They have a slight taper and he had cut them at a point they won't push through. Good enough for me, look ok, cheap to replace. Would take a sticker on face which is 55mm D
1966 Mini Deluxe - “Gabby” 34 years under restoration and counting...
1970 MGBGT
1959 MGA
