It is currently Sun Jun 29, 2025 11:39 am
 Post subject: SU Carby Part
PostPosted: Thu Jul 15, 2021 3:02 pm
I need the alloy plate that goes onto float bowl lid that covers the overflow hole. I know there must be thousands of these but I can't find the part number or description.
 Post subject: Re: SU Carby Part
PostPosted: Thu Jul 15, 2021 3:48 pm
AUC1215
PostPosted: Thu Jul 15, 2021 3:55 pm
I also need one. It is called a vent baffle and the part no. is AUC1215. If you find one at a reasonable price, let me know.
The best I have found in Oz is $9.01 + 14.50 shipping.
Cheers, Paul.
1970 Morris Mini K
PostPosted: Thu Jul 15, 2021 3:58 pm
It is called a Baffle Plate. More than that I don't know. Have you quizzed Burlen, or at least Midel?
Edit: It is AUC1215. Google that for suppliers.
PostPosted: Thu Jul 15, 2021 5:22 pm
I might have one, will check on Saturday
PostPosted: Thu Jul 15, 2021 5:39 pm
I will have more than some as well, but the OP hasn't made clear what he is after.
PostPosted: Thu Jul 15, 2021 9:17 pm
Baffle Plate, AUC1215. Great work guys. Now to do some hunting.
PostPosted: Fri Jul 16, 2021 5:04 am
Please correct me if I am wrong,but doesn't the fuel still come out of the vent with baffle fitted
if the float is not shutting off the fuel.Is the idea of the baffle to make the fuel come straight down instead of spraying everywhere?
1967 Morris mini Deluxe
1968 Buick Riviera
1979 HZ Kingswood
1979 CM Valiant
1982 Jaguar XJ6 series 3
2002 VX HSV
2013 Mazda 6
2018 Gt Mustang
PostPosted: Fri Jul 16, 2021 6:06 am
I think it’s just to direct the overflow downwards rather than spraying in a fine stream in the direction of the hole.
You can also get the later fuel bowl lids that accept a hose, that was you can put the hose away from the hot exhaust
PostPosted: Fri Jul 16, 2021 7:10 am
Thanks for info Timmy.I did have fuel coming out in that area a few months ago and I found the float stuck.
I do not know if i have a baffle fitted to mine,I will check later.
1968 Buick Riviera
1979 HZ Kingswood
1979 CM Valiant
2002 VX HSV
2013 Mazda 6
2018 Gt Mustang
PostPosted: Fri Jul 16, 2021 8:49 am
Just quizzed both of the above and found the part DavidE, thank you.
Maybe someone has a few these laying around they would like to pass on!
PostPosted: Sun Jul 18, 2021 3:20 pm
Found.
