It is currently Sun Jun 29, 2025 5:09 am
 Post subject: Headers - Pressed Steel
PostPosted: Wed Jul 14, 2021 3:09 pm
G'day all,
Through a series of fortunate conversations I've acquired a few boxes of Cooper/S parts.
Wondering if these headers are factory S by any chance?
Can't see any markings on them but despite the crappy joins they are in great nick.
Thanks and have a good day
Peter
;-) Pete...
____________________
1968 Deluxe 1275
1969 Deluxe 'Scruby' 998 Looking for a roof skin...
PostPosted: Wed Jul 14, 2021 8:06 pm
They look like the set that came on my early Mk2 S, the concertina piping looks to be a modification. The lower part of mine had been modified by a PO.
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1963 Triumph Spitfire
1982 RX-7 Series 2
PostPosted: Wed Jul 14, 2021 8:23 pm
Yours are the genuine pressed metal extractors as fitted to the Cooper, Cooper S and Clubman GT, but the bottom section has been cut off. and flexible exhaust added, unfortunately.
These sets are original.
Here's a set being manufactured at the Rubery Owen facility in the UK, suppliers to BMC.
PostPosted: Wed Jul 14, 2021 8:27 pm
This is the BMC engineering drawing for the extractors (part 12G615) that shows the correct bottom section.
PostPosted: Wed Jul 14, 2021 8:28 pm
Thanks Clive and Winabbey for the info and pics.
I knew the flex pipe was an addition, I guess they are worth the effort in reworking, they are nice and thick.
I'm not necessarily building a purist level 'S' clone but I do have S carbs to compliment them.
Much appreciated
Peter
;-) Pete...
1968 Deluxe 1275
PostPosted: Wed Jul 14, 2021 9:01 pm
Suggest you get them ceramic coated if you plan to use them on your car. They will last longer.
PostPosted: Wed Jul 14, 2021 9:05 pm
Solid plan!
;-) Pete...
1968 Deluxe 1275
PostPosted: Sat Jul 17, 2021 12:05 pm
IIRC, there are 2 versions of these.
The 1275 version is 1/4" taller than non 1275 versions as the 1275 block is 1/4" taller.
RonR
68 build Mk1 Cooper S
PostPosted: Sat Jul 17, 2021 3:11 pm
RonR
Good to know, since mine need the bottom half reworked, and I don't have an engine for this jalopy yet.
;-) Pete...
1968 Deluxe 1275
PostPosted: Sat Jul 17, 2021 5:58 pm
The parts books lists part 12A271 for the 997/998 Cooper, and the same or 12G615 as an alternative for the 1275 Cooper S, which suggests either will do and the 1/4" difference is not an issue.
PostPosted: Sun Jul 18, 2021 8:54 am
Just had a look at the engineering drawings for the two extractor types and note that the Cooper part 12A271 has a stem length of 6 7/8" while the S part 12G615 has a stem length of 7 5/32", so a difference of 9/32" (close enough to a quarter of an inch). How they were able to make them to those exact dimensions I don't know.
PostPosted: Sun Jul 18, 2021 7:36 pm
Jigs control the dimensions pretty well.....
Which bit is the "stem length" ?.... I'll measure the 1071 set I have.
Cheers, Ian
PostPosted: Sun Jul 18, 2021 9:53 pm
Cheers, Ian
This the length that differs between the two parts.
PostPosted: Mon Jul 19, 2021 11:15 am
The length difference is necessary to allow the bottom part of the pipe and clamp to match up with the clamp bolt hole on the remote housing. The bolt goes in from the top and can be vey difficult to align the pipe and clamp properly to get the bolt started without cross threading it..
It's a fiendish upside down arrangement that Heath-Robinson would be proud of.
Ron R
PostPosted: Mon Jul 19, 2021 9:27 pm
If I recall the shorter block units had the seam down the entire length...
Users browsing this forum: No registered users and 118 guests
