It is currently Sun Jun 29, 2025 2:23 pm
 Post subject: Running lean
PostPosted: Sat Jul 10, 2021 12:50 pm
Hi all
Great to have the forum back!
I had to replace the main jet pipe between the base of the carby and the fuel bowl.
Under choke it blows a heap of smoke then it’s fine
I checked a plug and it’s running very lean
Any thoughts of what is wrong as it was running perfect before the main jet tube was replaced
Thanks
 Post subject: Re: Running lean
PostPosted: Sat Jul 10, 2021 12:56 pm
Moderators please move to mini chat
PostPosted: Sat Jul 10, 2021 4:24 pm
Was it the correct size jet? There is .090 and .010
Did you reset the mixture adjustment?
Did you check the needle was still centred and the piston rises and falls smoothly?
Did you check the fuel bowl level?
