It is currently Sun Jun 29, 2025 7:44 am
PostPosted: Wed Jun 02, 2021 10:59 pm
Boot clean out surface rust in bottom of box needs treating
Before bottom of box rusts out!
PostPosted: Wed Jun 02, 2021 11:04 pm
Going to remove tank to clean boot floor behind . Surface rust where strap bolts to floor. Hope the tank isnt hiding any nasties.
PostPosted: Thu Jun 03, 2021 12:05 am
62cooper wrote:
It has wrong master cyl that i have just removed anybody know the correct master size all rest of brakes are standard
Going by this document (Stage 4 ) the brake master was reduced to 0.625" at car 2057. viewtopic.php?f=49&t=92146
PostPosted: Thu Jun 03, 2021 3:59 am
Ok thanks that helps .625 "
PostPosted: Thu Jun 03, 2021 8:21 am
Go for a Cooper S brake master cylinder. )0.7" bore and the larger/taller tank. Pretty sure you won't find a 0.625 master easily. To improve braking on the 997cc Cooper you can modify the calipers (simple machinig exercise) to accept the 998cc disk pads which are of greater size and still available from EBC.
PostPosted: Fri Jun 04, 2021 12:22 am
Does it matter which one of these i use. I seem to have more than one type in each size???
PostPosted: Fri Jun 04, 2021 12:25 am
Same in .75 size top is not the same???
PostPosted: Fri Jun 04, 2021 8:45 am
Ideally you need the 0.7" cylinder with the larger/taller reservoir can as per the Cooper S. Use the 0.75" cylinders for the clutch.
PostPosted: Fri Jun 04, 2021 5:52 pm
The clutch off car next to new one.
Mirror image of each other???
This clutch master still works fine just dirty.
Was going to refit.
PostPosted: Sat Jun 05, 2021 9:01 am
One of those is a brake MC.
PostPosted: Sat Jun 05, 2021 9:38 am
Online
The seal kits for the master cylinders are very cheap, might be worth stripping it down and checking them before you install them.
You’d hate to install them and then find they don’t work
