Hi Rick,
I haven't played with webers for a long time. Below are the jets in the two webers I have and have used on my previous Cooper S's. Hopefully, its of some use and doesn't muddy the water any further. I will be using weber #2 on my Mk 2 currently under restoration, suitably reconditioned and re-jetted to suit the new motor.
Your jetting: Italian 45 DCOE 13 34mm choke 145 main jet 190 air corrector F16 emulsion tube 30 pump jet 40F8 idle 5 aux Venturi 60F5 Cold Start jet
My carbs: From what I can remember , both seemed very good on their respected engines - no flat spots. It worked particularly well with the 649, nice grey exhaust pipe.
Weber #2 - Last used 1983 : 1310, period 35/75 cam & later a 649, lcb-1 7/8" single muffler, good head, balanced etc
Italian 45 DCOE 13 34mm choke 130 main jet 175 air corrector F2 emulsion tube 50 pump jet 50F9 idle 4.5 aux Venturi 50F9 Cold Start jet
Weber #1 - Last used 1980 : 1310, period 30/70 cam , sonic long 3-1 ,1 7/8" single muffler, mild head, balanced. Unfortunately, it has a broken flange when a mechanic tried to over tighten a bolt on the inlet manifold - hence weber #2
Italian 45 DCOE 13 34mm choke 145 main jet 180 air corrector F15 emulsion tube 50 pump jet 45F9 idle 4.5 aux Venturi 60F5 Cold Start jet
For what its worth, I've never used a choke on any of my webered cars, ranging from the Minis to a Alfetta Gt and my Dino. Just a couple of pumps and start with a bit of throttle as others have previously said.
_________________ 1970 Mk2 Cooper S under restoration
