It is currently Mon Jun 30, 2025 8:37 pm
 Post subject: Firewall insulation Mat
PostPosted: Thu Apr 22, 2021 7:02 pm
Had a go at making an original looking firewall mat for the cooper s
PostPosted: Thu Apr 22, 2021 7:07 pm
Please do tell more. I'd like to know the how and what.
Sent from my SM-G986B using Tapatalk
1965 Smooth roof Van
1969 Cooper S MK2
1970 Mini K
PostPosted: Thu Apr 22, 2021 7:50 pm
I managed to find the jute underlay and vinyl from a supplier in Australia.
The vinyl is used as a tornou cover on utes as I understand it.
I had the original firewall insulation mat from the car but it was in bad shape and not complete.
If you do a search on the forum under the title you will find a lot of information regards the two types of mats used and the grains of the vinyl and the colour which is almost a charcoal colour.
Forum members sent me some photo's of the complete firewall mat which helped to complete the correct shape.
I made a cardboard patten first and fitted it to find the correct locations of the cuts and then took the measurements from my old mat and came up with a nicely fitting end result.
You will need to make your judgment on colour and patten but when I put old with new side by side I'm very happy.
PostPosted: Thu Apr 22, 2021 9:04 pm
that's beautiful, well done!
PostPosted: Fri Apr 23, 2021 10:20 am
Sets off a very neat engine bay.
PostPosted: Sat Apr 24, 2021 4:38 am
Thanks Simon K and Bill B.
Iansmini67. I hope some of the information was of help.
PostPosted: Wed May 12, 2021 7:30 pm
@Firefirey, do you mind sharing the supplier details? Looks awesome. Thanks
PostPosted: Wed May 12, 2021 7:38 pm
Yes, Very helpful and really does look amazing. I'm with fffffred, I'd ben keen to know the suppliers please.
PostPosted: Thu May 13, 2021 7:41 am
Looks good. I had also been told a while back that the vinyl was the same as Ute cover.
The cut for the windscreen bottle, is that a long vertical slit almost to the bottom then a small horizontal slit? Does it fit around and over the bracket?
PostPosted: Sun May 16, 2021 7:14 pm
Hi Phil
My understanding is that the washer bottle bracket was screwed to the firewall and the insulation mat had the long cut - top to almost bottom with a small t - cut at the bottom which allowed the insulation mat to fit around the bracket and the washer bottle which makes a neat finish to the fitment of the insulation mat
PostPosted: Tue May 18, 2021 5:15 pm
Hi Phil
Thanks. Might consider doing that. Mine has the bracket screwed on top of mat, so I always have to unscrew/screw bracket to remove/fit mat.
