It is currently Sun Jun 29, 2025 12:30 pm
 Post subject: Steering Arm question
PostPosted: Sun Mar 21, 2021 12:52 pm
There is red/brown dust where the steering arm attaches to the hub. Does this mean there is movement where there shouldn't be movement?
PostPosted: Sun Mar 21, 2021 1:26 pm
I have the same on one of my minis. I suspect movement also and will investigate when I have time.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sun Mar 21, 2021 1:55 pm
Suspect worn holes in the swivel hub or arm. If they are worn oval, tightening the bolts won't help, even with new dowels. I had to change a swivel hub once due to this.
PostPosted: Sun Mar 21, 2021 3:23 pm
Are the dowels missing?
PostPosted: Sun Mar 21, 2021 3:28 pm
I was expecting something like that. Will be dismantling it soon.
At least all the bits are still available.
How tight a fit should the dowels be in the hub and in the arm?
If the arm needs replacing, should the other side's arm also be replaced too?
PostPosted: Sun Mar 21, 2021 3:40 pm
I doubt it. I'm about to strip it down.
It's a 1970 S I've owned since 1975 and other than replacing wheel bearings the hub is original. The L.H. CV is original but not serviceable now; the wheel bearings need replacing and the hub might be worn where the cups sit. Probably due for a refresh.
Oddly, the R.H. parts all good to go again.
PostPosted: Sun Mar 21, 2021 3:48 pm
Dowels are a neat fit, size for size.
Loosen the bolts slightly on the other arm, if you can move it sideways it has a problem too.
PostPosted: Sun Mar 21, 2021 5:48 pm
Maybe the dowels rusted out!
PostPosted: Sun Mar 21, 2021 6:48 pm
The hub and steering arm are now dismantled. There is a rust issue.
Soaking the parts in phosphoric acid to remove the rust and see what is happening.
PostPosted: Sun Mar 21, 2021 7:42 pm
Dowell looks like it has some wear
PostPosted: Sun Mar 21, 2021 8:37 pm
You need round dowels, round holes and a good fit.
PostPosted: Wed Apr 07, 2021 1:50 pm
Was thinking about using bearing retainer on assembling the new dowels. Are there any obvious problems that would create here?
Have sourced a good used steering arm and the hub holes are still a tight fit. The rear bolt was under a lot less tension than the other 3 bolts when dismantling them.
PostPosted: Wed Apr 07, 2021 2:12 pm
You can try Loctite 609 or similar bearing retainer. I used it successfully to retain a Timken front hub bearing so it should work. If you have trouble dismantling it later use a hot air gun.
PostPosted: Wed Apr 07, 2021 3:14 pm
Thanks for that, Dr M.
Users browsing this forum: Bing [Bot] and 87 guests
