It is currently Sun Jun 29, 2025 2:20 am
 Post subject: Engine knock....
PostPosted: Tue Apr 06, 2021 11:05 am
Well I think I have a problem.
My A+ 1275 seems to have developed a loud "rattle". I thought is was bad engine stabilisers/mounts but having a closer look the sound appears to be mid internal (below head height). It dose seem to go away in higher revs 2k+ but it's really loud at idle and power output seems the same.
What things can I check to try and rule out any other possible sources before I pull the engine out and split the box off?
 Post subject: Re: Engine knock....
PostPosted: Tue Apr 06, 2021 2:42 pm
Tappets would be the first possibility.
Cheers Dave.
PostPosted: Tue Apr 06, 2021 4:21 pm
Drop gears can rattle at low revs / low oil pressure
PostPosted: Tue Apr 06, 2021 8:01 pm
idler gear rattle
PostPosted: Wed Apr 07, 2021 11:15 am
What would cause the idler gears to rattle?
Oil pressure seems to be good 40-60psi at idle (hot and cold)
PostPosted: Wed Apr 07, 2021 12:28 pm
Idler + primary gears can rattle if engine is idling at low speed, particularly with a lightened or race flywheel and a sporty cam.
But that's a rattle, not a knock.
I would pull spark plug leads off, 1 at a time, if it goes away it's something related to that cylinder like a worn big end bearing.
If knock is there under load regardless of rpm it could be a broken crank, I've had a couple go.
PostPosted: Thu Apr 08, 2021 7:00 am
The engine has been in the car for over 5 years so it means something is broke........I'll try the leads and see what happens.
PostPosted: Thu Apr 08, 2021 8:02 am
What sort of driveshaft to engine type couplings?
PostPosted: Sat Apr 10, 2021 11:55 pm
Pot joint/cv's but the noise happens at idle when not moving.
PostPosted: Sun Apr 11, 2021 5:10 am
Does it go away when you push clutch in? And what is idling speed?
PostPosted: Sun Apr 11, 2021 8:43 pm
Idle is around 800.
I havn't noticed the clutch affecting it, I'll try to check soon.
PostPosted: Wed Apr 14, 2021 4:20 pm
Is it Crank speed or Cam speed knock.
Possibly broken cam follower or perhaps Bad piston or wrist pin.
