It is currently Sat Jun 28, 2025 5:08 pm
 Post subject: Radiator AAAHHKKK
PostPosted: Mon Mar 29, 2021 8:49 pm
The radiator in the paddock bomb has sprung a weeping leak.
Nothing quite like replacing a mini radiator to fully test and squash the sense of humour. :x
Cheers Dave.
 Post subject: Re: Radiator AAAHHKKK
PostPosted: Wed Mar 31, 2021 3:54 pm
For a paddock bomb, it just needs a dose of pepper and leave rad cap lose. Drove like that for over 12 months in the old Hilux.
PostPosted: Wed Mar 31, 2021 4:37 pm
Is there a trick to it as I have never had it work for me.
Cheers Dave.
PostPosted: Tue Apr 06, 2021 11:11 am
Pepper floats so the water level needs to get down to the leak, then as the pepper flows out it gets stuck in the hole and seals it.
Plus u need a fair bit sometimes if the leak is a distance away from the cap as the pepper may stick to the internals as it flows to the leak.
PostPosted: Tue Apr 06, 2021 2:40 pm
Yeah.
I think I will just replace the rad.
Cheers Dave.
PostPosted: Wed Apr 07, 2021 11:27 am
Good choice
PostPosted: Thu Apr 08, 2021 8:40 am
What started out as a slight weep developed into a full scale deluge when running the engine to do the mixture. I ended up standing in water on the shed floor.
So I decided to open the can of worms, the T/stat housing was crumbling, one of the bolts sheared and the lower cowl fell to bits.
I now have a 1/4 inch sheared bolt to play with.
You gotta love a mini don't you. :x :roll: :evil:
Cheers Dave.
PostPosted: Sat Apr 10, 2021 11:59 pm
On the bright side, now you have started you'll have a fully rebuilt mini in about 10 years, so long as you stick to the "while I'm in there" mentality.
