It is currently Sun Jun 29, 2025 1:19 pm
PostPosted: Sun Feb 28, 2021 11:10 am
Does anyone know casting numbers or other identifiers to tell if a crank is a 1098. Going to look at a job lot of parts, trying to find a 1098 crank..
Thanks
PostPosted: Sun Feb 28, 2021 11:28 am
12G82
PostPosted: Sun Feb 28, 2021 11:44 am
Thanks, fingers crossed
PostPosted: Sun Feb 28, 2021 12:43 pm
Was it the same for all 1098, ie from Morris 1100 to clubman?
PostPosted: Sun Feb 28, 2021 12:52 pm
I believe it was the only part number for 1100 cranks.
PostPosted: Sun Feb 28, 2021 4:43 pm
Crack test it before you part with $$$.
They are much more likely to crack than 998 ones.
They need a good fillet radius to survive, sadly some crank grinders don't know or don't care.
I've thrown 2 over the years because of this.
Last one had been reground -0.010" undersize and was hardly worn.
PostPosted: Sun Feb 28, 2021 7:08 pm
Oh dear, worry, worry...
HI Simon
You will find that most 1100 cranks have yellow paint on them, and not all of them have a cut out on the two centre counter weights where they drill down through the centre main to number 2 and 3 pins for the oil way.
Graham Russell
PostPosted: Sun Feb 28, 2021 9:00 pm
We found one, no chance of crack testing it though - it was still in a block and had probably never been out of it since new... grabbed that and a couple of rod change boxes.
You may see it in your workshop in the near future GR ;)
PostPosted: Mon Mar 01, 2021 7:49 am
Was Sime in Bowral on Sunday :?: :arrow:
PostPosted: Wed Mar 03, 2021 1:18 pm
or 12G2827. I have a few left
PostPosted: Wed Mar 03, 2021 1:42 pm
They’re the special ones :D . Big bore 1100!
