It is currently Sat Jun 21, 2025 8:27 am
PostPosted: Mon Feb 22, 2021 2:28 pm
In the photo below I have installed tail lights into an 850 shell for a project that I am working on, however the tail lights do not have White Reversing Lights.
What model mini has the white reversing lights that fit into the same body housing as these.
Regards
Phil
PostPosted: Mon Feb 22, 2021 3:29 pm
There are some on eBay, I can’t tell what specific model they come from
Eg
https://www.ebay.com.au/itm/MINI-COOPER ... 890.l49292
PostPosted: Mon Feb 22, 2021 4:08 pm
Yes, there are lots on eBay, but I need someone that knows for sure that they will fit into the body without modification in place of the current ones I have.
PostPosted: Tue Feb 23, 2021 11:15 am
Those lights are from the first generation R50, 02 - 04 which has a single central reverse light on the bumper. 2004/5 saw the facelift R50 released which had the reverse light in the tail light assembly and fog light in place of the central reverse. You need lights from 04-07 (ish) facelift R50.
1971 Clubman GT - Jet Red
1980 Mini 1000 - Bold As Brass
1967 Riley Elf - Red/White
2002 MINI Cooper - BRG/White
2005 MINI Cooper - BRG/White
2022 MINI Cooper SE - BRG/White
PostPosted: Tue Feb 23, 2021 8:28 pm
These are listed as R50, R52, R52 2006/6
They look like the same installation as my current ones.
Are these the ones you mean ClubmamGT.
https://www.ecstuning.com/News/MINI_R50 ... 2007_2008/
PostPosted: Wed Feb 24, 2021 2:54 am
Yes, they are the ones.
PostPosted: Wed Feb 24, 2021 8:45 pm
Awesome, thanks ClubmanGT
PostPosted: Fri Feb 26, 2021 8:28 pm
Picked up a pair of tail lights today and the left is a bit hazy.
I’ve looked on line and am a bit nervous about using wet n dry on plastic.
Everyone recommends it but I’m yet to be convinced.
I did use some Maguires Scratch X and it did improve it a bit. Perhaps more elbow grease is required.
Any recommendations ?
PostPosted: Fri Feb 26, 2021 8:31 pm
I used a headlight restoration kit - basically just some fine polish and a polishing attachment that fits in the drill.
https://www.autobarn.com.au/mothers-nul ... enewal-kit
PostPosted: Sat Feb 27, 2021 7:59 am
use 600 grit wet and dry sandpaper wet, follow up with autosol, then brasso
they will come up as good as new,
