It is currently Sun Jun 29, 2025 6:20 am
Post new topic Reply to topic  [ 16 posts ]  Go to page Previous  1, 2
PostPosted: Mon Feb 15, 2021 2:35 pm
timmy201 wrote:
The recovery cap has a separate little piece in the middle of the underside of the cap. It’s spring loaded and allows the coolant back in when the system cools and the pressure drops. I’m pretty sure you need the specific recovery cap
Thanks for your comments on this, Timmy. I've learned more than I expected! I rang Mini Sport and they told me there was no long neck cap for overflow modifications.
The original style mini cap (like the one in the photo you first posted) does have a small spring-loaded valve in the centre of the main sealing ring assembly. I assume it is meant to allow air to pass into the radiator when the pressure/temperature starts to drop - in the same way that the recovery caps also have that valve to allow coolant to move to the radiator.
The real difference (I'm making this up now) is that the modern recovery caps have a seal under the top of the cap to prevent air entering the filler neck and maintaining a vacuum to draw liquid back in from the overflow tank.
