It is currently Sun Jun 29, 2025 9:23 am
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
 Post subject: Re: Timken bearings
PostPosted: Wed Feb 10, 2021 6:13 pm
Hey all just pressed the new bearings in about to refit on the car. I have two orings in the packaging where do they go?
PostPosted: Thu Feb 11, 2021 5:13 am
Mini Spares tells you:
"O RING GOES BETWEEN FIRST BEARING AND BACKPLATE ON STUB AXLE, radius arms have a recess for the seal."
PostPosted: Fri Feb 12, 2021 8:04 am
If you are struggling to find Timken bearings, you can also use SKF (have their own steel plant) and FAG. They are both high quality bearings. Reputable bearing suppliers can get them.
