It is currently Tue Jul 01, 2025 8:08 am
PostPosted: Sun Jan 31, 2021 1:13 pm
Hi all
My mini k is leaking fuel.
It seems that a spiral looking pipe from the bowl to the base of the carbie has come apart
How do you fix this?
Thanks in advance
PostPosted: Sun Jan 31, 2021 1:32 pm
It's part of the main jet. Buy a new one and that hose is included.
PostPosted: Sun Jan 31, 2021 1:40 pm
Thanks doc
Is it just a case of ordering a 11/4 jet?
Are there many variants
Thanks
PostPosted: Sun Jan 31, 2021 3:44 pm
P/no TK6000
jet 0.090"
For HS2 and HS4 SU.
From Karcraft catalogue.
PostPosted: Sun Jan 31, 2021 3:58 pm
P/no TK6000
jet 0.090"
For HS2 and HS4 SU.
This what it looks like - https://minisport.com.au/mini-moke-su-main-jet-090-type
PostPosted: Sun Jan 31, 2021 8:12 pm
Legend Doc
PostPosted: Mon Feb 01, 2021 7:24 pm
There are a few details that need to be observed when fitting a new jet between the carby and float bowl - especially where the plastic tube is connected to the bottom of the float bowl. Look at a workshop manual to see where the plastic tube is sealed by the O ring at the fuel bowl. This is a common site of fuel leaks. Sometimes, you are lucky and the leak just needs the 1/4AF nut to be tightened very lightly.
