It is currently Thu Aug 21, 2025 3:17 pm
 Post subject: Engine Will Not Rotate
PostPosted: Sat Jan 16, 2021 5:24 pm
Just mated the gearbox and engine. Started turning the crankshaft by hand to see if all is well. Then after 1 & 4 pistons went down and 2 & 3 pistons came up there was a sudden stop and the 2 middle pistons stuck half way.
Any ideas?
PostPosted: Sat Jan 16, 2021 6:13 pm
Is the head and valve train on
PostPosted: Sat Jan 16, 2021 6:25 pm
Just the gearbox and block
PostPosted: Sat Jan 16, 2021 6:44 pm
No transfer case
PostPosted: Sat Jan 16, 2021 7:03 pm
And differential
PostPosted: Sat Jan 16, 2021 7:07 pm
What gearbox case do you have? Some of the early ones didn’t have clearance for the long stroke 1275
PostPosted: Sat Jan 16, 2021 7:10 pm
22G1128
PostPosted: Sat Jan 16, 2021 7:56 pm
Did you install the distributor drive spindle? It might have fallen out
PostPosted: Sat Jan 16, 2021 8:02 pm
I took out the distributor drive spindle.
I guess I'm going to remove the gearbox to see if I can see any problems.
PostPosted: Sun Jan 17, 2021 9:17 am
Found it guys. A trick for old players. I changed the oil filter housing to a spin on housing and used bolts that were too long and these intrude to far into the block not allowing the crank to turn. Good to find this out before going too far into the build. WHAT A DUFFER.
PostPosted: Sun Jan 17, 2021 11:19 am
That is a good thing to make note of for the future for me!
Graham
1974 Leyland Clubman
Lots of good machines
Of all the things I have lost, I miss my mind the most.
PostPosted: Sun Jan 17, 2021 12:23 pm
duly noted! that's one I haven't heard before!
PostPosted: Sun Jan 17, 2021 12:59 pm
Use sealant( like Permatex #3 )on the threads of the bolts otherwise oil will leak up the threads to the outside
Studs are normally used as they seal when they bottom out
Users browsing this forum: BBY755 and 252 guests
