It is currently Tue Jul 01, 2025 5:22 pm
PostPosted: Mon Dec 21, 2020 8:37 am
My front wiring loom has been abused with many soldered in wires some of which are melted.
The above picture is a 9 pin connector to the rear loom (which is fine).
Where can I buy a replacement front loom with black tape for a 1969 Mk2 Cooper S with an external regulator that will plug into the pictured 9 pin rear plug? A part number might help track one down.
PostPosted: Mon Dec 21, 2020 10:06 am
https://www.vinwire.com.au/
PostPosted: Mon Dec 21, 2020 12:30 pm
The MK II Cooper S main harness (i.e. front) part number is AYA9221, or 9223 with reversing lights and 9224 with two speed wipers and reversing lights (the last two originally for SPO41 spec vehicles).
PostPosted: Mon Dec 21, 2020 12:38 pm
Thanks winabbey
PostPosted: Mon Dec 21, 2020 3:02 pm
Has anybody used the Vinwire Mk2 front harness and did it mate up to the existing rear harness?
PostPosted: Mon Dec 21, 2020 5:05 pm
Yeas it does! There is a spare wire at my wiper motor for 2 speed motor. Even a circuit for a thermal fan, if you want one. Also a a wire for tachometer. Can highly recommend Vinwire.
PostPosted: Mon Dec 21, 2020 8:33 pm
Does the Vinwire loom have the correct 9 pin plug or just bullet connectors?
Users browsing this forum: Bing [Bot], drmini in aust and 92 guests
