It is currently Tue Jul 01, 2025 12:58 am
 Post subject: Rubber Uni's
PostPosted: Tue Oct 06, 2020 8:35 am
When did the mark one Cooper S cars change from Rubber Uni's to Hardi Spicer units?
 Post subject: Re: Rubber Uni's
PostPosted: Tue Oct 06, 2020 9:07 am
Car No 1918 approx mid 1966.
From Dark Blue Mini workshop manual TP832 specifications section
It refers to engine number 1918 but that is the car number.
No S had an engine number 1918.
RonR
68 build Mk1 Cooper S
PostPosted: Tue Oct 06, 2020 9:58 am
RonR
Thanks for that reference Ron.
I have been using Engine 41233 / 41234 as the changeover. Taken from the MK1 Performance conversions site. - http://mk1-performance-conversions.co.uk/gearboxes.pdf
But car 1918 has a later engine. I will have to update my list.
PostPosted: Tue Oct 06, 2020 11:37 am
My first S was car No 1090 and had the rubber unis. Purchased July 66 from Gould's Motors in High Street Northcote. I don't know the actual build date but probably late 65 or early 66.
The LH one was replaced 2/3 times in 60K plus miles. RH one never replaced.
I was a bit peeved when I found that later build cars had the steel unis and the large oil cooler. IIRC they were added before the Bathurst 66 race.
I traded this in for my current S.
RonR
PostPosted: Tue Oct 06, 2020 1:48 pm
RonR
Ron - systematic change with blue hydro displacers being introduced at this same car #?
F
PostPosted: Tue Oct 06, 2020 10:01 pm
According to TP832, displacers were Double Orange to car 1917, Blue to car 3715 and Silver from car 3716.
Also Clubman GT Silver.
RonR
PostPosted: Wed Oct 07, 2020 8:03 am
RonR
If by lefthand you mean the nearside, then perfectly understandable with some of our Goat Track roads! :shock:
PostPosted: Wed Oct 07, 2020 9:56 am
The LHS drive shaft is also shorter than the RHS and for the same amount of wheel travel the LH uni moves through a slightly larger angle than the the RHS.
Is this angular difference enough to cause an increase in the wear rate of the LHS rubber uni?
Who knows.
RonR
PostPosted: Wed Oct 07, 2020 7:43 pm
Who knows.
RonR
As we drive on the left hand side of the road, left turns are sharper than right turns. So the left uni and boot get worked a lot more.
Phil
PostPosted: Wed Oct 07, 2020 7:58 pm
Who knows.
RonR
Phil
I've got one -- short left side driveshaft absorbs less torque than the longer right, meaning the left side CV has more torque load applied to it
PostPosted: Thu Oct 08, 2020 7:27 am
Listen to this Lady! :D
https://www.centralwesterndaily.com.au/ ... up-street/
