It is currently Thu Jul 03, 2025 4:14 pm
 Post subject: cooper S fuel tanks
PostPosted: Sat Sep 05, 2020 1:22 pm
Hi,
having problems with the R/H fuel tank not providing fuel and only left (passenger side) tank working... Any ideas of what problem may be. Many thanks
 Post subject: Re: cooper S fuel tanks
PostPosted: Sat Sep 05, 2020 1:56 pm
Johnnymac wrote:
Hi,
Check the little breather hole in top of tank isn't blocked. Mine was, after I rust converted the inside of the tank.
Poke a drill through it.
PostPosted: Sat Sep 05, 2020 7:57 pm
Thanks Doc
PostPosted: Sun Sep 06, 2020 4:42 pm
Could the outlet at the bottom of the RH tank be blocked with sludge? Also the interconnecting pipe may be blocked between the RH outlet and the takeoff for the fuel pump which is closer to the LH tank.
PostPosted: Mon Sep 07, 2020 8:26 am
Great thanks BB will check it out.
PostPosted: Mon Sep 07, 2020 7:41 pm
Check out the rubber fuel line between tank and solid interconnect line. If tank has been removed and flex line crimped with multi grips, the fuel line may well have taken a set and blocked fuel flow. I'm just speaking from experience. :?
1970 Mk2
1968 Mk1 project
PostPosted: Tue Sep 08, 2020 8:14 am
Thanks mozzie....hornets nest....lower pipe..
