It is currently Sun Jun 22, 2025 10:26 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Fri Aug 28, 2020 10:07 am
After contacting the eBay supplier I used, it turns out he has supplied me LG2 (leaded) bronze, not phosphor bronze.
I will have to get some more material and make another bush! :(
Bugger thats no good
Sent from my SM-J530Y using Tapatalk
PostPosted: Sat Aug 29, 2020 9:30 am
This illustrates the hazard of buying stuff online.
Oils ain't oils and bronzes ain't bronzes. I need PB1 not LG2.
I have just found a local supplier, will go there on Monday.
PostPosted: Sat Aug 29, 2020 10:42 am
What about using c932 bronze alloy.
PostPosted: Sat Aug 29, 2020 4:14 pm
[color=#FF0000][color=#BFFF00][/color][/color]
That's a leaded bronze similar to LG2.
I've used LG2 leaded bronze for offset rocker bushes but phosphor bronze is better for highly loaded bushes. And higher speeds.
Edit:
C932 alloy does have some phosphorus and not too much lead so probably is OK. Among its uses is diesel wrist (gudgeon) pin bushes so it must be pretty tough.
PostPosted: Mon Aug 31, 2020 11:04 am
I got some 1" dia PB1 phosphor bronze bar from Brass and Copper in Seven Hills.
I'll get another bush turned up.
Edit:
I'm also drilling a hole between 1st and 2nd gears on the cluster, and adding grooves to the small thrust washer, to improve oil flow.
Edit 2:
New bush finished, I've given its bore 1-1/2 thou clearance to promote oil flow.
Last edited by drmini in aust on Wed Sep 02, 2020 3:56 pm, edited 1 time in total.
PostPosted: Tue Sep 01, 2020 4:21 pm
cooperess wrote:
Is this where the extra oil feed holes should go and should they go all the way through to the other side.
Just needs 1 hole between 1st and 2nd gear, not right through both sides. And radius the corner.
Also add a couple of radial grooves to the small thrust washer.
Said GR.
Edit:
I'll put it into my son's 1300 + remote box here that's going into his 71 Clubby before Xmas I hope!
Saves pulling mine out again.
PostPosted: Fri Oct 09, 2020 3:52 pm
Reclaimed S cluster gear and phosphor bronze bush fitted.
Bore of small end is now 22mm not 21.
Edit:
I kept the 2 big needle bearings in the other end, the gear has no wear there. It's the small diameter bearing in the 1st gear end that usually suffers, along with the shaft there.
Last edited by drmini in aust on Fri Oct 09, 2020 9:02 pm, edited 1 time in total.
PostPosted: Fri Oct 09, 2020 6:47 pm
well done Kevin. my gear is fixed but no time to put it together, just starting on our house extention so thats got to take priority.
PostPosted: Sat Jan 13, 2024 5:05 pm
I had an odd noise in my gearbox at the end of the day at Hay last year, turns out the small idler gear bearing had collapsed
Part of the bearing cage was still there, but all of the rollers were gone. The shaft might have been rubbing on the gear itself, but not much
After a cleanup, a new bearing slides in there, but the surface is quite rough - definitely not the same nicely ground finish as the other end
Use as-is?
Repair as described in this thread?
Buy another and put this aside for "fix it one day"?
edit: the 1st gear teeth have taken a little bit of damage, they were grinding on the selector ridge of reverse (I think)
PostPosted: Sat Jan 13, 2024 8:27 pm
I drilled a 6mm hole where the RH mark is. I only bushed the small end.
I only drilled one side, Graham Russell suggested later drill right through would be better.
Anyhow it's been on the road now for 2 years, running fine. No bronze in the oil when drained last. But it's on club plates so only done 1000 miles or so.
PostPosted: Sat Jan 13, 2024 8:53 pm
Would you run a bushed gear under your 1360 or a 1406 stroker motorkhana car?
I measured the bore of a (good) K laygear and the damaged one - the bore looks to be 0.825" (33/40") - the calipers slip cleanly into the K gear, and need a bit of a wiggle to get into the damaged one. Maybe the damage can be ground out, will a couple of thou oversize hurt a roller bearing?
PostPosted: Sat Jan 13, 2024 9:28 pm
I'd grind it out parallel and fit a bush.
No the overstressed needle bearing won't like the oversized hole, mine collapsed on the way to Rylstone a few years ago.
Yes I would run a bush in my 1360, or the 1412 if I still had that.
Edit
I reckon it'll stop the shaft case hardening getting chewed up as usually happens..
Last edited by drmini in aust on Sun Jan 14, 2024 7:22 am, edited 1 time in total.
PostPosted: Sat Jan 13, 2024 10:41 pm
thanks Kev :)
PostPosted: Sun Jan 14, 2024 4:54 am
I also filed a V groove across the small bronze thrust washer to promote oil circulation.
Users browsing this forum: No registered users and 112 guests
