It is currently Thu Jul 03, 2025 4:29 am
 Post subject: FAJS Weber
PostPosted: Sat Aug 15, 2020 6:53 am
I'm looking at replacing the Solex Mikuni carb for my mini when I finally have it running and came across the FAJS Weber. I looked on the Weber website which said that it is a Chinese copy of the weber 40dcoe but not up to the same standard. But looking around at different Weber carb set ups and nearly all that I seen in packages use the FAJS carb.
Does anyone have any experience using this carb?
Are they any good? Or just junk?
Any help would be appreciated.
Thanks.
 Post subject: Re: FAJS Weber
PostPosted: Sat Aug 15, 2020 8:07 am
My friend James had a couple
The first IDF copy leaked fuel out of the carb body and had to get replaced
The DCOE copy was just poor quality - threads were really soft
A good condition used Weber or Dellorto is my choice. Other people might have been lucky with the FAJS ones
PostPosted: Sat Aug 15, 2020 10:08 am
I agree with Dr. A second-hand Weber or Dellorto with a kit put through it will always be better then a poor quality replica.
