It is currently Thu Jul 03, 2025 7:21 am
 Post subject: Mini k outer door sills
PostPosted: Wed Aug 05, 2020 10:49 am
Hi all,
I've just purchased a mini k rolling shell which needs a bit of work on the shell. The drivers sill is rusted and has an outer sill welded over the top. I am planning on replacing both sills but not sure what the original sill looked like. Just confirming it is the same as the Mk1 with the 4 indents. I saw on the youtube video below a 1969 mini k which has 6 raised sections on the sill (about 29-30 seconds into clip) but is this original?:
https://youtu.be/6LA6sZOwSdA
PostPosted: Wed Aug 05, 2020 12:04 pm
Australian cars had 1 vent at the rear
PostPosted: Wed Aug 05, 2020 12:16 pm
These are the ones available on minibits.com.au
PostPosted: Thu Aug 06, 2020 7:42 pm
I would use the 4 vent mk1 panel, you will get a better finish as the curve is shaped in to it.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Fri Aug 07, 2020 5:10 am
I personally wouldn't use any of the pictured the top 2 are horrible cover sills and the bottom one needs a curve in it
PostPosted: Sat Aug 08, 2020 6:37 pm
Which non-cover sill would you recommend? Could you send a link. I was thinking of this as an option:
https://oz.minisport.com/mcr11-33-01-28 ... mk1-3.html
PostPosted: Sat Aug 08, 2020 8:09 pm
Are you restoring for originality?
PostPosted: Mon Aug 10, 2020 6:43 pm
Yeah, it's stripped down completely for a rebuild so may as well get it looking as original as possible. There is an over-sill on the drivers side at the moment which I'll remove. The drivers footwell is ok but has been patch in a couple of places and there is hole towards the back. The mk1 complete sill to 1st groove should sort out all the rough parts.
