It is currently Wed Jul 02, 2025 12:36 am
PostPosted: Sun Aug 02, 2020 6:11 pm
I have 3 different fans on my parts shelf.
Steel fan, Yellow plastic, and White Plastic.
Is there much difference between all 3?
Obviously the steel fan is heavier than the plastic, but which moves air better?
Want to get the best air flow with the least amount of HP loss.
I do have a Thermo fan kit but i want to save that for my next build.
New Alloy radiator, rebuilt engine and gearbox going in soon, new hoses actually pretty much new everything.
If its got tits or wheels its gonna cost you
1973 Solid side Leyland Mini Panelvan 1100 in Hairy Lime(Elma)
1976 Clubby project in progress
1966 Morris Mini Deluxe in need of a full resto
1971 Mini K Garden Art
PostPosted: Sun Aug 02, 2020 8:36 pm
I remembered Vizard had a bit of advice in his white book so I looked it up...
He likes the 2 blade fans the most but apparently they are unobtainable, after that he seems to like about 16 blade plastic as they have an airfoil shaped blades and is consequently more efficient and costs less power.
This is not from my experience just passing the info on.
From my experience though there's quite a bit of airflow through the radiator at speed, I run an electric fan only in my engine conversion with the radiator in the standard spot, I've driven up to 2hrs without the fan coming on, I have a light on the dash for when the fan comes on , radiator is a non standard custom job with high fin count and triple pass, despite this if the air wasn't flowing it would need the fan.
Roads need more corners
PostPosted: Mon Aug 03, 2020 5:18 am
I like the 16 blade steel ones they don't shed blades when old.
The 4 (2x2) blade comp steel ones are better but noisier.
PostPosted: Mon Aug 03, 2020 10:33 am
just throw the white plastic fan in the bin. They become very brittle with age.
PostPosted: Mon Aug 03, 2020 12:16 pm
Hi Doc, What is your opinion of the Dowty 4 blade variable pitch fan? No longer available, sometimes see one on eBay overseas.
https://encrypted-tbn0.gstatic.com/imag ... e8QM7XqA&s
PostPosted: Mon Aug 03, 2020 12:28 pm
... unless you are trying to keep a car as original as possible, in which case the white fan is essential.
A shame they are no longer made. Perhaps some off-white satin paint on a yellow version would suffice.
PostPosted: Mon Aug 03, 2020 3:14 pm
They yellow fan blades are different to the white ones.
PostPosted: Mon Aug 03, 2020 3:54 pm
The yellow plastic ones comes in several different versions (blade width varies). The white ones have the widest blades in the plastic family.
Cheers, Ian
PostPosted: Mon Aug 03, 2020 5:13 pm
Yes
PostPosted: Mon Aug 03, 2020 6:44 pm
I have seen several comments about the white plastic fan's in regards to their performance which leads me to ask if BMC Australia put out a service bulletin to have the fan's changed at any point?
When I purchased my car a number of years ago it had a 16 narrow bladed yellow plastic fan. :?
PostPosted: Mon Aug 03, 2020 6:59 pm
I've never owned one but recall a test in a UK mag years ago that reckoned they work ok.
Not sure if it was a Mini one or was on some other pommy car.
PostPosted: Tue Aug 04, 2020 8:37 pm
Checked my Steel fan, its the 16 blade steel one. Guess I'll clean it up, repaint it and use that one.
Eventually the 1100 will go back into the wife 76 Leyland.
Mine will get a 1275 so I'll worry about a fan when i build that one.
