It is currently Thu Jul 03, 2025 2:34 am
Post new topic Reply to topic  [ 65 posts ]  Go to page Previous  1, 2, 3, 4, 5
PostPosted: Tue Jul 28, 2020 5:57 pm
Mizuho Kimura wrote:
Does the rocker cover of mk1 1275S have no breather pipe?
Correct - no rocker cover breather.
Breathing is done from the rear tappet cover breather to the inlet manifold through a PCV valve.
PostPosted: Tue Jul 28, 2020 7:50 pm
And the oil cap is vented, so that is the source of the crankcase ventilation
PostPosted: Wed Nov 04, 2020 7:20 pm
Hello, I have been long silence.
As everyone told me
I took a picture of the driver's side of the wall,
There was no number there.
PostPosted: Wed Nov 04, 2020 7:50 pm
And I checked the radiator shroud again,
I didn't know after M2.
PostPosted: Thu Nov 05, 2020 6:56 am
The number on the firewall should be in your second photo near the master cylinders. It looks like quite a few layers of paint in that area, you may need bare metal to see them ?
1966 Mini Deluxe - “Gabby” 34 years under restoration and counting...
1970 MGBGT
1959 MGA
